4th gen jdm headlight cutoff
Old Apr 21, 2004 | 03:09 PM
stRodda's Avatar
Default 4th gen jdm headlight cutoff
that guard or cap that covers the lowbeam bulb... is the edge that creates the cutoff on the top or bottom edge?
Old Apr 21, 2004 | 05:17 PM
The_Todd's Avatar
Farts in the shower
Default Re: 4th gen jdm headlight cutoff (stRodda)
No its the housing and the cap that create the "pattern"
to my knowledge the JDM headlights for the 4th gen do not have a cut off pattern
Old Apr 21, 2004 | 11:43 PM
stRodda's Avatar
Default Re: 4th gen jdm headlight cutoff (VRDrvr)
there is some minor glare, but there is an obvious cutoff. my plan was to cut the edge that doesnt create the top cutoff, as to let more light out directly at the ground.
ill try and get a pic
Old Apr 21, 2004 | 11:59 PM
stRodda's Avatar
as you can see, there is a distinct top cutoff. and it almost looks like there is a bottom cutoff too... below the intense light center, theres almost no light below it. i want to cut the guard to increase that light.
Old Apr 23, 2004 | 09:55 PM
stRodda's Avatar
so... anyone know if its possible to increase the light by cutting one edge of the cap? if yes, how should i do it and not affect the top cutoff... i dont want to blind people.
Old Apr 23, 2004 | 10:10 PM
usc's Avatar
usc
cutting the top part of the cap will do very little to increase the light on the foreground. the problem isn't the cap. the lamp was designed for the light to be reflected from the rear. if they wanted to design more light onto the ground, they would need to make the lamps bigger and the reflector rounder towards the top.
Old Apr 24, 2004 | 09:56 AM
.bagged's Avatar
Default Re: 4th gen jdm headlight cutoff (usc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usc &raquo;</TD></TR><TR><TD CLASS="quote">cutting the top part of the cap will do very little to increase the light on the foreground. the problem isn't the cap. the lamp was designed for the light to be reflected from the rear. if they wanted to design more light onto the ground, they would need to make the lamps bigger and the reflector rounder towards the top.</TD></TR></TABLE>
Hence Projector Lens' w/cutoff
Old Apr 24, 2004 | 05:27 PM
stRodda's Avatar
oh, ic. so its not meant to have a strong light right in front of the car, but instead a less intense broader light... right
sshp
Apr 5, 2006 11:17 AM
jerry5150
Apr 16, 2004 10:08 AM
020
Jul 3, 2003 06:40 PM
