Anyway to run 225/50-15s all around?
Old Oct 30, 2001 | 05:51 PM
Jon7's Avatar
Default Anyway to run 225/50-15s all around?
Interested in this, but with SSR competitions in 15 x 7.5 rims. Are spacers needed or fender rolling? I remember the 98 DC sports type Rs ran this combo.
Thanks.
Old Oct 30, 2001 | 06:03 PM
SpeedPak's Avatar
Default Re: Anyway to run 225/50-15s all around? (Jon7)
i ran this set up for racing for a long time, (still do). You will need 1/4 inch spacers, H&R sells a set w/ the longer studs, i know the car still rubs in the front inner fender under full lock, but just a little. I havent had any problems with having to roll the fenders, but i never drove them like that on the street for extended periods of time.
BTW i was running the kuhmo victoracer on the stock 15x6 wheel.
fais
Old Oct 30, 2001 | 06:22 PM
citanest's Avatar
New User
Default Re: Anyway to run 225/50-15s all around? (SpeedPak)
Speedpak, that's interesting. Do you need to change the studs? They are pretty damn hard to change. Have to take out the drive shafts as well. Also, which tires do you use, Khumho, RA1, A032?
Do you put spacers on both the front and the back?
Old Oct 30, 2001 | 07:17 PM
Hracer's Avatar
New User
Default Re: Anyway to run 225/50-15s all around? (citanest)
I also ran 225/50-15s all around on the stock 15x6 wheels. All it needs are 1/4 inch spacers for the back to prevent the insides of the rear tires from rubbing the rear control arm. I ran this with v700s and previously with BFG g-force R1s. Since hoosiers are wider than normal, 225s will not fit all around and people using Hoosiers run on 225s front/205s rear in the stock class.
I am sure with certain modifications you can fit 225s all around on 7-inch wide wheels, which makes a much better fit for these tires.
Old Oct 30, 2001 | 07:42 PM
yoshi234's Avatar
I shoot brides
has anyone tried the Kosei K1 wheels w/ the 225s all around?
yoshi- who might just keep the autox spec tires for track use ala JDM-style
Old Oct 30, 2001 | 08:10 PM
BryanSprinkel's Avatar
225's will slow ya down, too heavy
Bryan
Old Oct 30, 2001 | 08:14 PM
Hybrid ctr's Avatar
Default Re: Anyway to run 225/50-15s all around? (VAtypeR00)
how will 225's all around affect your turning ability
Old Oct 30, 2001 | 08:33 PM
Default Re: Anyway to run 225/50-15s all around? (Hybrid ctr)
225's will put more tire to the ground, but will also decrease speed. It will take more to turn them.....
Bryan
Root of all Evil
Sep 6, 2011 08:05 PM
petwhookie
17
Feb 20, 2009 06:28 PM
deepgreengsr
Mar 8, 2003 07:43 PM
Back in Black
Apr 22, 2002 12:24 PM
KekeK-18
17
Dec 2, 2001 10:22 PM
