is there potential in the D16Z6 engine????
Old Apr 21, 2004 | 01:21 PM
dynamicRacing719's Avatar
Default is there potential in the D16Z6 engine????
I currently have a D16Z6, but i dont know if i should work on the motor or should i swap it out.
Does any one know how much money and hp a all motor D16Z6
is be? How about boosting on this motor, how good is that?
Thanks
Old Apr 21, 2004 | 01:22 PM
bad93ex's Avatar
Default Re: is there potential in the D16Z6 engine???? (dynamicRacing719)
Rebuild, then boost.
Also, search.
Old Apr 21, 2004 | 01:24 PM
barto's Avatar
theres a lot of potential for the z6. building an n/a project out of a d-series (although possible) would take up quite a bit of money for good results. most people that modify the d series boost it. you can throw on a turbo on a stock z6 and run about 7 psi safely although it is reccomended you build up your motor first. for the price of a swap you could get some pretty good numbers.
Old Apr 21, 2004 | 01:34 PM
Discosteak's Avatar
d16z6@12 psi https://honda-tech.com/zerothread?id=821860
dunejunkie
Sep 10, 2014 08:52 AM
tca0bell
15
Apr 8, 2005 10:59 AM
Generic User Name
Jan 4, 2005 06:03 PM
90SICRX
11
May 8, 2004 02:21 PM
demon_hatch
Jun 29, 2003 06:30 AM
