What suspension setup should I get for my Teg?
Old Apr 21, 2004 | 12:04 PM
BrokeAssAcura's Avatar
Default What suspension setup should I get for my Teg?
I'm looking for a suspension setup on my 94 LS that has minimal bounce, extremely tight for corners and pretty durable as far as longevity. Could anyone please tell me what would be good choices as far as this is concerned? Thank you very much.
Old Apr 21, 2004 | 12:05 PM
ragerized's Avatar
Default Re: What suspension setup should I get for my Teg? (BrokeAssAcura)
its all about how much you want to spend. tein is a good all around coilover.
Old Apr 21, 2004 | 12:15 PM
Audi A4's Avatar
Default Re: What suspension setup should I get for my Teg? (ragerized)
excatly.. serach a little, cause this is like what turbo kit should i get ya know... everyone has mixed opinions... do a search and then go with ur gut
Old Apr 21, 2004 | 12:43 PM
TeamSTEALTH GSR's Avatar
H&R race springs with Koni yellows... good street set up
Old Apr 21, 2004 | 01:46 PM
Kendall's Avatar
Koni yellows are a solid choice as far as shocks, but there are numerous choices as far as springs that will suit you. Ground Control makes their setups in whatever spring rate you want.
Old Apr 21, 2004 | 01:55 PM
imbigmikey's Avatar
Default Tein SS Model, the self Adjustable
you'll love the the Tein SS type if you have $1200 roughly to play with, otherwise go with H&R and Koni Setup, its not to shab for the price, and the difference is noticable but both have there + & -...
mikey
imbigmikey@hotmail.com
Old Apr 21, 2004 | 03:50 PM
R.S.'s Avatar
Default Re: Tein SS Model, the self Adjustable (imbigmikey)
Koni yellow shocks
ground control coilover sleeves w/ custom spring rate eibach springs
i have that set up, i have 6kg/mm front and 7 rear, it's a daily driver and i love my set up.......
Old Apr 21, 2004 | 03:52 PM
02_IT-S's Avatar
i just got tein stechs on and they have a great ride and a perfect drop.
Old Apr 21, 2004 | 04:00 PM
b18punk's Avatar
i have the eibach prokit over kyb agx's and its awesome
Old Apr 21, 2004 | 04:02 PM
Kendall's Avatar
If money isn't an issue, consider something crazy like Ohlins PCV.
Old Apr 21, 2004 | 04:27 PM
JunIntegra's Avatar
Default Re: (Kendall)
JIC gets my vote
Old Apr 21, 2004 | 04:45 PM
non_VTEC's Avatar
Default Re: (JunIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunIntegra &raquo;</TD></TR><TR><TD CLASS="quote">JIC gets my vote</TD></TR></TABLE>
I agree, JIC Magic has some very nice higher end coilovers. So does cusco. There are many companies out there that will suit your needs. There are higher end Teins that you might like. If you are willing to shell out some cash, go for Ohlins PCV.
You'll want to upgrade your rear sway as well, considering you have a '94 LS you may want to upgrade you front sway bar as well. There are many companies that make good sways as well, it all depends on how much you want to spend. For instance there is Comptech, Suspension Techniques, and eibach just to name a few. These have been covered numerous times, just take some time to search and find out what fits your needs best.
Old Apr 21, 2004 | 05:02 PM
IntEGNYC's Avatar
for longevity, go with stock.
Old Apr 21, 2004 | 05:06 PM
Kendall's Avatar
Default Re: What suspension setup should I get for my Teg? (IntEGNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">for longevity, go with stock. </TD></TR></TABLE>
I'll drink to that.
Old Apr 21, 2004 | 06:10 PM
FlaN.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">If money isn't an issue, consider something crazy like Ohlins PCV. </TD></TR></TABLE>
not everyones baller like you,
Old Apr 21, 2004 | 06:26 PM
bert039's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imbigmikey &raquo;</TD></TR><TR><TD CLASS="quote">you'll love the the Tein SS type if you have $1200 roughly to play with, otherwise go with H&R and Koni Setup, its not to shab for the price, and the difference is noticable but both have there + & -...
mikey
imbigmikey@hotmail.com</TD></TR></TABLE>
you mean the HA's or somthing else right? I've seen SS's go for under $900 right here on H-T.
personally i don't see how you could go wrong with koni and a custom ground control setup
Old Apr 21, 2004 | 07:25 PM
GotGSR's Avatar
Default Re: Tein SS Model, the self Adjustable (bert039)
SS's you can find for 800 flat...
longevity= KONI....lifetime warrenty, plus you can rebuild em. GREAT customer service from what I hear. That's one of the reason's I bought em!!!
Old Apr 21, 2004 | 07:28 PM
FlaN.'s Avatar
Default Re: Tein SS Model, the self Adjustable (GotGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GotGSR &raquo;</TD></TR><TR><TD CLASS="quote">SS's you can find for 800 flat...
longevity= KONI....lifetime warrenty, plus you can rebuild em. GREAT customer service from what I hear. That's one of the reason's I bought em!!!</TD></TR></TABLE>
the Tein SS's are re-valveable also.
just thought i'd throw that in thurr
Old Apr 21, 2004 | 07:31 PM
Kendall's Avatar
Default Re: Tein SS Model, the self Adjustable (FlaN.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlaN. &raquo;</TD></TR><TR><TD CLASS="quote">the Tein SS's are re-valveable also.
just thought i'd throw that in thurr</TD></TR></TABLE>
However the Tein SS setup isn't nearly as track worthy as a well matched Koni/GC setup. And the Koni/GC setup should run for about the same price, if not cheaper.
Old Apr 22, 2004 | 11:06 AM
arvinacebedo's Avatar
Default Re: Tein SS Model, the self Adjustable (Kendall)
KONI YELLOWS ARE KOO BUT I DONT SUGGEST THEM CUZ I HAVE THEM ON MY TEGGY AND THEY SUCK ***. YOULL BE BETER OFF WITH THE TEIN SS
Old Apr 22, 2004 | 01:17 PM
Default Re: Tein SS Model, the self Adjustable (arvinacebedo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arvinacebedo &raquo;</TD></TR><TR><TD CLASS="quote">KONI YELLOWS ARE KOO BUT I DONT SUGGEST THEM CUZ I HAVE THEM ON MY TEGGY AND THEY SUCK ***. YOULL BE BETER OFF WITH THE TEIN SS </TD></TR></TABLE>
why do they suck? share your bad experiance
Old Apr 23, 2004 | 03:40 PM
Well, I didn't think I'd really get this much reply...thank you for your input. I'm lookin for a setup that'll be around $500-1000 and will ride sweet. I heard that the kyb agx is a pretty sweet shock/strut.
Old Apr 23, 2004 | 04:18 PM
Kendall's Avatar
Default Re: (BrokeAssAcura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssAcura &raquo;</TD></TR><TR><TD CLASS="quote">I heard that the kyb agx is a pretty sweet shock/strut.</TD></TR></TABLE>
Good, yes. As good as the Koni's, in my opinion no.
Old Apr 23, 2004 | 09:12 PM
Dc2 David's Avatar
springs - eibach or h&r
coilover sleeves - ground control 2nd to none!
shocks struts - koni yellow or tokico adjustables
true coilover - tein ss
avio
Suspension & Brakes
Apr 15, 2010 04:04 PM
happyman12
Feb 6, 2004 04:14 PM
90teg
Jan 7, 2004 06:17 AM
lastlude2k1se
Aug 13, 2003 09:19 AM
Adampops
Jun 17, 2002 02:33 PM
