JDM shift knob on 98-01 GSR
Old Apr 21, 2004 | 12:00 PM
joshalee's Avatar
Default JDM shift **** on 98-01 GSR
So I think I got a RSX or maybe USDM type r shift ****.
My question is the nut. I put it on the nut first, then the **** and it will straighten out the numbers, however it seems to loosen quickly.
I took off the nut and screwed on the **** directly and it tightens, but of course the numbering doesn't line up.
Is there something I'm doing wrong? It is common for the **** to loosen w/ the nut?
Old Apr 21, 2004 | 12:13 PM
Audi A4's Avatar
Default Re: JDM shift **** on 98-01 GSR (joshalee)
put the not down first all the way, then screw the shift know ALMOST all the way down.. then tighned the nut on to the shift ****, of course line the #'s up 1st... so have a wrench handy
Old Apr 21, 2004 | 03:59 PM
mugenracer's Avatar
I think the nut looks ugly so do what i did to get the numbers to line up, get a hack saw and cut the top thread of the shifter, then screw on the **** and see how it lines up, if its still off, file (dremell???) off a little of the top of the shifter and try again (only file the smallest amount, maybe a 10th of a mm, i was lucky in that i managed to get it absolutely 100% straight and murder tight on my second attempt and not having to use the nut shortens tha shift lenght slightly also!
Old Apr 21, 2004 | 06:11 PM
Audi A4's Avatar
Default Re: (mugenracer)
can u post pics mugenracer?
Old Apr 21, 2004 | 06:41 PM
Smeeg Heed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">I think the nut looks ugly so do what i did to get the numbers to line up, get a hack saw and cut the top thread of the shifter, then screw on the **** and see how it lines up, if its still off, file (dremell???) off a little of the top of the shifter and try again (only file the smallest amount, maybe a 10th of a mm, i was lucky in that i managed to get it absolutely 100% straight and murder tight on my second attempt and not having to use the nut shortens tha shift lenght slightly also!</TD></TR></TABLE>
I wadded up small pieces of paper and put them inside the shift ****. Kept tightening, taking it off, adding more paper, tightening it again, etc. Not a very technical way to do it but it works.
dc2LS
Jul 27, 2010 07:26 PM
06SI=superior
Honda Civic (2006 - 2015)
Mar 26, 2007 01:33 PM
skata89
Oct 20, 2005 11:15 AM
civicboy95
May 6, 2002 10:48 AM
joemama
May 24, 2001 05:01 PM
