which intake are people using? stock air box w/ spoon filter?
Old Apr 21, 2004 | 10:44 AM
todaspecsi's Avatar
Default which intake are people using? stock air box w/ spoon filter?
Hey I was wondering what intake setup people are using? I was lookin into the stock air box with the spoon filter? Anyone currently use that? Can the Spoon filter be cleaned or do you have to buy a new one later?... Post pics to if you can.
Old Apr 21, 2004 | 10:53 AM
spoonbenny's Avatar
Default Re: which intake are people using? stock air box w/ spoon filter? (todaspecsi)
I guess tha'ts cool if you want to do that JDM thing, but i won't net you much ponies. I'm rocking a Short Ram intake 3'' pipe with an HKS foam filter. HOttttttt shiiiiiiiiittttttttttt. It's cheap and very effective. I have some dryer tube aimed at it fo much fresh air. THose filters are re-washable.
Good luck hookin' yur car up.
Old Apr 21, 2004 | 10:56 AM
spoonbenny's Avatar
My bad, i saw the pics of your car, and it's nice. I would stick with the J's racing , mega intake. That **** is dope. I use to have one, unitl some bastard stole it.
Old Apr 21, 2004 | 11:06 AM
cre18's Avatar
Default Re: which intake are people using? stock air box w/ spoon filter? (spoonbenny)
j's intake
Old Apr 21, 2004 | 12:22 PM
sicivic12's Avatar
If you going all engine...then AEM is a good choice. If you doing supercharging...short ram fo sho. Most intakes will give you the same amount of performance, its a personaly preference. I had an AEM CAI on my 2000 SI, worked nicely.
Old Apr 21, 2004 | 12:29 PM
OEMedUP's Avatar
Default Re: which intake are people using? stock air box w/ spoon filter? (sicivic12)
j's racing is good. personally i'd go w/ the aem just for the simple fact of the look. i hate the j's racing pipe.. looks as tho its either a slug or some sort of peice of plastic that got melted around something and formed over your intake. but the hks is a good way to go as well you get slightly diff. sounds w/ a cone filter and a dome one as well (more of a wistle w/ a dome). also they are easy to clean = dome. however as a simple suggestion take what money you have in your pocket and look on here for a good buy.
Old Apr 21, 2004 | 03:36 PM
StErN's Avatar
Default Re: which intake are people using? stock air box w/ spoon filter? (OEMedUP)
Iceman cold air.
Old Apr 22, 2004 | 01:53 PM
OEMedUP's Avatar
Default Re: which intake are people using? stock air box w/ spoon filter? (StErN)
Old Apr 22, 2004 | 01:58 PM
daklown's Avatar
Dat Dere Cell Tech
my friend put a sock on his intake
Old Apr 22, 2004 | 03:33 PM
cccya's Avatar
Default Re: which intake are people using? stock air box w/ spoon filter? (daklown)
ITR AEM with an Apexi filter.
d16z6 yo!
Old Apr 22, 2004 | 03:39 PM
Pnoymugen's Avatar
Injen RD CAI
da935oul's Avatar
AEM CAI w/ K & N Filter but i would like to try the J's Racing phat intake.
Old Apr 22, 2004 | 03:42 PM
EL-Driver's Avatar
I am using a 3 inch Short ram intake tube cut too fit a 94 EG Air box with K&N Filter...
and H22 throttle body... on D16Y8 in my 99 Civic EX....
works great and noticed a difference on the low end side of things....
Old Apr 22, 2004 | 03:45 PM
2slo2ugly's Avatar
Default Re: which intake are people using? stock air box w/ spoon filter? (EL-Driver)
AEM CAI in my hatch and cheapo short ram in my sedan
Old Apr 22, 2004 | 03:46 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonbenny &raquo;</TD></TR><TR><TD CLASS="quote">I'm rocking a Short Ram intake 3'' pipe with an HKS foam filter. HOttttttt shiiiiiiiiittttttttttt. It's cheap and very effective</TD></TR></TABLE>
did you dyno before and after? From everything I've read the HKS filters are pretty crappy with making power and so are short-ram (Hot Air) intakes . . . . .
Old Apr 22, 2004 | 03:51 PM
SawBoss's Avatar
Default Re: which intake are people using? stock air box w/ spoon filter? (nonsense)
AEM short-ram intake. Cheapest I found for CARB.
Old Apr 22, 2004 | 04:06 PM
TwistedSI's Avatar
Default Re: which intake are people using? stock air box w/ spoon filter? (SawBoss)
AEM copy with K&N
Old Apr 22, 2004 | 04:07 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
I've never been a big fan of foam filters.
I'd go with a K&N.
Unless you're into that JDM bling crap.
Old Apr 22, 2004 | 04:41 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by todaspecsi &raquo;</TD></TR><TR><TD CLASS="quote">Hey I was wondering what intake setup people are using? I was lookin into the stock air box with the spoon filter? Anyone currently use that? Can the Spoon filter be cleaned or do you have to buy a new one later?... Post pics to if you can.</TD></TR></TABLE>
If you want the OEM look, why not just use a K&N panel filter? Cheaper than the Spoon, and washable, readily available everywhere.
Old Apr 22, 2004 | 05:48 PM
todaspecsi's Avatar
Default Re: which intake are people using? stock air box w/ spoon filter? (rodrez)
i heard the spoon is washable....i'm sellin my j's on here cuz i want the stock look again. torn between what i should get
Old Apr 22, 2004 | 06:27 PM
mr poo's Avatar
foam filters suck
Old Apr 22, 2004 | 06:33 PM
sleeping beauty's Avatar
I'm all for keeping your car looking clean/sleeper/oem or whatever, but I'm not so sure I would want to give up performance for a look. With all the dyno's I've seen here that show what the J's intake can do, if I already had one I would keep it.
Old Apr 22, 2004 | 06:44 PM
todaspecsi's Avatar
Default Re: (sleeping beauty)
i already sold it
Old Apr 22, 2004 | 06:58 PM
POE's Avatar
POE
Default Re: which intake are people using? stock air box w/ spoon filter? (TwistedSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwistedSI &raquo;</TD></TR><TR><TD CLASS="quote">AEM copy with K&N
i have the same intake on my car, but i turned it into short ram so iwould not take on any water aboard.
Old Apr 22, 2004 | 07:01 PM
HATCHingMN's Avatar
Default Re: which intake are people using? stock air box w/ spoon filter? (cre18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cre18 &raquo;</TD></TR><TR><TD CLASS="quote">j's intake </TD></TR></TABLE>
yes the huge ***** intake gets my vote too
