I need some engine flushing ideas.....
Old Apr 21, 2004 | 08:48 AM
Beat2Shit's Avatar
Default I need some engine flushing ideas.....
My block where the water runs through is clogged. What can I use to flush it out??? I have been recommended to use SeaFoam...but I need some other ideas as I have heard good and bad things about it.
Anything helps!!
Old Apr 21, 2004 | 09:22 AM
jfastman's Avatar
Default Re: I need some engine flushing ideas..... (Beat2Shit)
Powdered Cascade dishwashing detergent works awesome. Make sure you flush with plenty of h2o when yer done!
Old Apr 21, 2004 | 10:08 AM
Beat2Shit's Avatar
Default Re: I need some engine flushing ideas..... (jfastman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfastman &raquo;</TD></TR><TR><TD CLASS="quote">Powdered Cascade dishwashing detergent works awesome. Make sure you flush with plenty of h2o when yer done!</TD></TR></TABLE>
How long would it take to rinse out??
Old Apr 21, 2004 | 12:24 PM
jfastman's Avatar
till the water is clean. the whole process should take about an hour. email ?'s to jfastman@yahoo.com
Old Apr 21, 2004 | 04:57 PM
Beat2Shit's Avatar
Any other ideas? And I tried adding you to my buddy list but it didn't add......you got YahooIM?
Old Apr 21, 2004 | 10:38 PM
matix's Avatar
Use seafoam I just did my h22 and my freinds car. !/3 brake booster,1/3 in gas tank,1/3 in oil. Just be ready to see a lot of smoke when you add it to brake booster if you do it.
Old Apr 22, 2004 | 05:06 AM
streetspeed607's Avatar
Youse karosen, ive read this many times berfore, fluchses the hell outta ur engine and it helps stock engine leaks, ill try to find the right up about it for u
Old Apr 22, 2004 | 11:25 AM
Beat2Shit's Avatar
Default Re: I need some engine flushing ideas..... (matix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matix &raquo;</TD></TR><TR><TD CLASS="quote">Use seafoam I just did my h22 and my freinds car. !/3 brake booster,1/3 in gas tank,1/3 in oil. Just be ready to see a lot of smoke when you add it to brake booster if you do it.</TD></TR></TABLE>
1/3 in brake booster....?? Gas and oil? The clog is where the water is supposed to run through. The radiator is brand new and functions fine. Water pump is brand new. Water just isn't getting through the block. How would running that through the gas/brakes/oil fix the water clog problem??
Ferarrikiller
Sep 13, 2008 03:59 AM
q8delsol
14
Oct 10, 2006 10:16 AM
92ehatch
35
Nov 8, 2005 07:20 PM
FBP Si 2000
Sep 4, 2004 10:35 AM
hatchback
Jun 26, 2003 07:08 PM
