A Challenge for you all detailed info on the B16A2 engine
Ok here is a challenge for you all I need to know some very detailed info on the B16A2 engine, to put into a software programme called Dyno2003 it takes all your engine info and show what your BHP is and by changing setup you can see what effect mods will have
Now the problem is I need to know some very detailed information, I need to know;
* Intake Lift at valve in Inches
* Exhaust Lift at Valve in Inches
* Lifter Acceleration Rate
I also need to know valve opening/closing based on Set-
To-Seat like
* Primary Timing IVO
* Primary Timing IVC
* Primary Timing EVO
* Primary Timing EVC
* Intake Duration
* Exhaust Duration
* Intake Centreline Angle
* Exhaust Centreline Angle
* Lobe Centreline Angle
* Valve Overlap
I also need to know about;
* Bore
* Stroke
* Intake Valve Dia
* Exhaust Valve Dia
So if any one is up to a challenge and able to provide any or all of the info I need then let me know
Thanks a lot
To-Seat like
* Intake Duration
* Exhaust Duration
* Valve Overlap
* Bore
* Stroke
* Intake Valve Dia
* Exhaust Valve Dia
Thanks a lot
wagon-r
Jun 11, 2013 09:32 AM
