turbo ls
Old Apr 21, 2004 | 06:32 AM
n2oteg's Avatar
Default turbo ls
im wanting to turbo my 94 ls next summer since my car will be paid off this dec. I want to push about 10-15psi inorder to pull that off what all would need to be done to the engine to beable to withstand that with no problems? and about how much hp would that bring my car too?
Old Apr 21, 2004 | 06:57 AM
IntegraBoy04's Avatar
Default Re: turbo ls (n2oteg)
You need to search ALOT, and learn alot more before you do it.
Old Apr 21, 2004 | 07:00 AM
n2oteg's Avatar
Default Re: turbo ls (IntegraBoy04)
well I wont be doing it myself a shop will be doing it....I know I gotta get forged internals and injectors.etc.
Old Apr 21, 2004 | 07:34 AM
Audi A4's Avatar
like said b4 man search... to push 15 pds you need money, injectors, pistons, fuel managment... etc... ask the gurus in the FI forum.
Old Apr 21, 2004 | 07:39 AM
SIK IN DA HED's Avatar
New User
you need to figure out what type of turbo will suit your hp needs. a t3t4 is a good size turbo... but depending on your setup, you will have to figure out what specifications you want.
with that much psi, you will want to get a Hondata setup. good fuel management and tuning is the key!
quikB18B's Avatar
Default Re: turbo ls (DRAG lll INTEGRA)
Im running 14.5 psi(1 bar) daily on my Stock Ls, It is tuned conservatively however. You should base your goals/limits with hp, not boost. Remmeber you can make different power #'s with different psi, due to bigger vs smaller turbo's, and exhuast sizing, ect.... The smaller turbo will take more psi to make the same #'s as lets say a bigger turbo would so kepe that in mind.
As far as your goals, you'll need bigger injectors, An ems, hondata, aem, uberdata ect.... as far as fuel management is concerned.
blacc_ej1
Mar 2, 2009 11:42 PM
slowex98
Aug 28, 2008 06:58 AM
97_civickid
Jan 21, 2008 04:07 PM
andymangsr94
Feb 5, 2006 04:00 PM
sExy_TinKY
Sep 7, 2003 07:37 PM
