oil in sprank plugs
Old Apr 20, 2004 | 09:53 PM
TYPE_R'01's Avatar
Default oil in sprank plugs
i have oil in my sprak plugs, what is cusing this problem? and is it seious?
Old Apr 20, 2004 | 09:58 PM
jiahanhao's Avatar
Default Re: oil in sprank plugs (TYPE_R'01)
sorry, misread your post... i thought you said coolant (dunno why)
it could be as simple as the spark plug seals on the valve cover... check these out first
Old Apr 20, 2004 | 10:01 PM
jiahanhao's Avatar
Default Re: oil in sprank plugs (jiahanhao)
is the oil on the insulator part or, on the lower part?
Old Apr 20, 2004 | 10:10 PM
TYPE_R'01's Avatar
its on the lower part of the spark plug, so does that mean the O-ring is bad and need changing? and where is the O-ring located anyway?
Old Apr 20, 2004 | 10:28 PM
jiahanhao's Avatar
no, that's worse, it could be bad piston rings, valve seals, lotta different reasons.. i suggest a compression test. the o-rings are on the underside of the valve cover...
Old Apr 21, 2004 | 01:03 AM
kkim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TYPE_R'01 &raquo;</TD></TR><TR><TD CLASS="quote">its on the lower part of the spark plug, so does that mean the O-ring is bad and need changing? and where is the O-ring located anyway?</TD></TR></TABLE>
define "lower part of the spark plug".
Old Apr 21, 2004 | 01:05 AM
B2FiNiTY's Avatar
Replace the spark plug gaskets and then see if the problem is still there.
mafia
Mar 26, 2010 10:13 PM
usdmEHboy
Jul 23, 2007 09:08 AM
alghafat424
Feb 11, 2006 12:35 PM
illusion
Apr 30, 2003 06:47 PM
si91
May 28, 2002 07:33 AM
