can i swap a f22b1 head for a f22a4 head?
Old Apr 20, 2004 | 08:01 PM
as i lay dying's Avatar
Default can i swap a f22b1 head for a f22a4 head?
do u think i sould swap my head to a f22b1 for mine cause i was planning on gettin a engine swap but if i can't then i was thinkin of puttin a new head and adding cold air and v-tec but i'm not sure if i can replace my head with a f22b1 for my f22a4 can i even do it and if i can swap the head what good mods can i do?
Old Apr 21, 2004 | 10:36 AM
fw190bvi's Avatar
Default Re: can i swap a f22b1 head for a f22a4 head? (as i lay dying)
i believe you can swap the heads from b's to a's and vice versa....but unless u know what ur doing, its <U>alot</U> of work, mainly concerning the vtec...ull also need a new ECU to run vtec
Old Apr 21, 2004 | 12:56 PM
Default Re: can i swap a f22b1 head for a f22a4 head? (fw190bvi)
will i gain any hp from swaping my head ?
Old Apr 21, 2004 | 01:00 PM
what year would be good for me to use the f22b1 on my 90 accord 2.2 litier engine for the swap on the head?
Old Apr 21, 2004 | 01:20 PM
kittedaccord's Avatar
yes , u can do it. i think there is a thread on here about it. the horses are minimal compared to a swap maybe 10 horses max .
Old Apr 21, 2004 | 02:18 PM
Default Re: can i swap a f22b1 head for a f22a4 head? (kittedaccord)
how much would u say a f22b1 head is ?
Old Apr 21, 2004 | 04:26 PM
fizzbob7's Avatar
you could make more power with a cam and tuning.......and it's a lot less work
Old Apr 21, 2004 | 05:48 PM
fw190bvi's Avatar
junk yards are ur friends....but i have no clue as to the going rate......if u get the head, and it turns out its bad, use it to teach urself how to port, and go at it!
Johnst185
Apr 25, 2010 02:36 PM
Nate13
15
Dec 16, 2009 10:50 AM
bigsnorlax
Sep 29, 2008 09:09 AM
as i lay dying
Apr 20, 2004 08:45 PM
phthalo
Apr 20, 2004 07:41 PM
