Already Searched - brake line problem
Old Apr 20, 2004 | 07:29 PM
OKSolSi's Avatar
Default Already Searched - brake line problem
I was bleeding my brake lines and was stupid enough to let the reservoir go dry and now that I've refilled it, the line wont purge (if thats the right terminology). What I mean is no brake fluid will flow to the rear brake lines, which are the only two I have attempted to drain. Fluid drained out fine at first, but the reservoir emptied, and since being refilled no matter what I do the lines will not flow. Anyone know what the problem could be?
Modified by OKSolSi at 5:09 AM 4/21/2004
Old Apr 20, 2004 | 07:32 PM
jolt-tsp's Avatar
Default Re: Already Searched - brake line problem (OKSolSi)
Have you tried leaving the bleeder open while pumping it?
Old Apr 20, 2004 | 07:33 PM
2lua's Avatar
keep try to pump slowly and hold, eventually fluid will flow. you are doing this with some help right?
Old Apr 20, 2004 | 08:11 PM
OKSolSi's Avatar
Default Re: Already Searched - brake line problem (2lua)
Yeah guys I've tried it all.
I've pumped the pedal with the bleeder closed to build pressure, then opened the bleeder, and nothing flows.
I've opened the bleeder and pumped the pedal and nothing flows, the fluid in the reservoir stays at a constant level.
And yes, I have someone pumping the brakes while I watch the line.
Old Apr 20, 2004 | 08:13 PM
Sliced Beard's Avatar
you will have to bleed the master cylinder in order for it to pump fluid
wgbm92
Feb 17, 2013 05:18 PM
WhiteOnRice
Suspension & Brakes
10
Nov 3, 2012 03:45 AM
itzyaboyzeem03
Sep 21, 2008 05:19 AM
Team Bukkake Sucks!!!
11
Dec 13, 2006 09:27 AM
mickey513
Dec 2, 2003 07:53 AM
