stock connecting rod bolt---how do you remove it?
I need to replace the connecting rod bolts on my B16a2. The bolts are in there(on the big end of the connecting rod) pretty tight. I've tried to gently tap it with a deadblow hammer, but will not budge.
How do you go about replacing these? I hope I don't have to press it out.
hahah! thanks for the suggestion.
I'm talking about the rod bolt off the big end of the connecting rod. If you notice, the bolt had is oval shaped, so you can't turn it.
put one nut in and turn it til it bottom out at the shoulder of the bolt, then put another nut and turn it til it bottom out with the first nut, then tighten it then use a box end wrench and turn the bottom nut to loosen the rod bolt.
forsakenriceboy86
Dec 7, 2009 12:05 PM
kornerk12
Jul 1, 2009 03:54 PM
integrawow
11
Jun 8, 2009 05:49 PM
