would you run this rod bolt?
Old Jun 1, 2015 | 12:43 PM
blackeg's Avatar
Default would you run this rod bolt?
i may be crazy, but it looks like the bolt on the left saw some heat/has some discoloration to it. it was the only one like that, and is pictured next to the other rod bolt from my #3 cyl rod. eagle h beams and arp 2000's. bolts were torqued to 43 ftlbs with the moly. motor was around 500 hp and never had any major or catastrophic incidents. the bearing looks good and no discoloration of the rod itself. i dont have a stretch gauge but with my dial calipers it measured the same as the other bolts
Old Jun 1, 2015 | 01:37 PM
Dark_Teg's Avatar
Default Re: would you run this rod bolt?
When in doubt throw it out especially when its a cheap part.
Old Jun 1, 2015 | 01:57 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
This x2.
Old Jun 1, 2015 | 03:28 PM
wantboost's Avatar
Who is Mr Robot?
I agree with the above. Even though the bolt might be perfectly fine if you have a doubt, replace it.
Old Jun 1, 2015 | 06:00 PM
Muckman's Avatar
Moderator in Chief
Even new rod bolts are usually a few thou different length over the range of the set. Are you telling me yours are all exactly the same length?
Old Jun 6, 2015 | 03:40 AM
blackeg's Avatar
i couldnt notice a difference with the dial caliper. its graduated at .001, so between that im estimating. the needle was in pretty close to the same place, which id have to say is about .0002ish deviation to the other bolt from the same rod. id assume more than that id notice the needle on the dial gauge being off a bit. i need a good micrometer set both for smaller things like this and to measure piston diameter as well. its on my list of things to buy this month.
kornerk12
Jul 1, 2009 03:54 PM
tommyj
Apr 22, 2007 02:16 PM
importboi22
Nov 5, 2003 07:24 AM
GOLDBERG
Sep 5, 2003 03:04 AM
