What prop valve came in the '97 Del Sol Si? Plus a few more questions...
1:What prop valve came in the '97 del sol si?(the non abs one with 4 wheel disk brakes if it was a option) Is it a 4040 or a 3040?
3:Did this model come with the larger front disk brakes? Or the smaller size like those on the older eh civics.
Thanks
Modified by func-tion at 6:54 PM 4/20/2004
Modified by func-tion at 7:01 PM 4/20/2004
Thanks
I compared the part number to the one for my '92 si and they are different.
I just bought a gsr brake swap. And if the 97delsol si has larger front brakes and the same prop valve (3040) as the one in my si. I Wont worry about changing it. But if its different may have to invest in a new valve.
Thaks that probably what I will end up with.
But I would still like to know what prop valve the delsol comes with because it has the larger front brakes and more similar weight distribution to my car than a gsr does.
the prop valve i have came off a del sol vtec(b16 powered). It has unrecognizable markings on it. However, it was on a del sol that had rear discs. BTW im trying to rid of my rear disc set up. I'm wanting to let it go for 200obo PM me for details
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowboarderguy44 »</TD></TR><TR><TD CLASS="quote">the prop valve i have came off a del sol vtec(b16 powered)</TD></TR></TABLE>
Was it abs equipped? Because I think th abs equipped cars just have distribution blocks and no prop valve.
the sol did not have abs, when i pulled it. the commom box by the intake that controls the abs was not present. besides when doing a brake swap i wud worry more about complete ebrake cables and master cylinder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowboarderguy44 »</TD></TR><TR><TD CLASS="quote"> besides when doing a brake swap i wud worry more about complete ebrake cables and master cylinder </TD></TR></TABLE>
I have a 15/16ths master cylinder and my brake swap came with everything. I have the entior front cross member, steering rack, cables, shocks, rear lca's camber links and the rear swaybar. everything...
Just need a prop valve.
I asked newman what prop valve came on eg6's because he has a few front clips and he said 4030.
EG6's have a similar weight distribution a eh2's and there brake setup is similar to those found on a gsr's.
What usdm honda has a 4030 prop valve?
the proportioning valve is the same as in a dx with small brakes the rear disk is also smaller
and the front brakes are not the same as the delsol vtec or gsr so the proportioning valve front brakes , rear brakes and booster and master cylinder will be needed
DRKSol
Jun 4, 2007 07:51 AM
snowboarderguy44
Nov 14, 2003 09:23 AM
