LS Swap final check
I am going to do my swap next week. I have a 1995 Honda Civic CX hatch. I am swapping a B18B Ls.
I have all the motor mounts from the ls, i use the front and rear tranny mounts from the civic correct?
I need to change the o2 sensor to a 4 wire? if so how do i wire this up?
can i use the Civic wiring harness? my ls harness has been cut
i use the ls drive axles
i use the ls ecu
i use the ls throttle cable
i use the ls shift linkage
which radiator hoses do i use? civic or integra
Any other good information????
i use the ls ecu
What model is your civic? cx or dx? If cx then you'll have to do the 4 wire covnversion. I dont have the info right now but i can help you out with wiring. Yes you can use the civic harness. You'll have to lengthen some wires. Best way to do it would be to put the civic wiring harness on the b18b1 motor while it out. Start with the distrbutor and plug up the connectors from your civic wiring harness. Then just work your way around the motor plugging up all the connectors, iat, iacv, injectors, vss sensor, and so on. For radiator hose use the ls one. For the lower radiator hose use the ls one also. And get some hose clamps.
preetyboi06
Jul 17, 2009 09:57 AM
Midwestrider
Oct 29, 2002 04:12 AM
