Yeah yeah, i know...a rear sway question for EK hatch...
MiG-21 superfan
OK. I have a lower tie bar (neuspeed, but have a dc i can put on instead)
I want a rear sway, and it seems Suspension Techniques offers a complete rear kit to fit my car (incl. endlinks and all, since it had no orig. stock rear sway), but it will interfere with the lower tie accoring to the manufacturer, so do i get the beaks spacer kit (the gold things) and ill be ok?
I am not spending 255+ship for the entire kit (bar and all) from beaks...
What is the simplest solution here? I also would like to drill as little as possible and keep things from tearing apart or out...
I got hte S/T rear sway on my ek, if you want I can take pics for you and you can see if they interfear with the lower tie bar...I would think they do since they use the same holes, but I can't recall off the top of my head
let me know
let me know
if you go with the beaks kit you will not have any problems mounting your DC lower tie bar, they do not use the same mounting points. you also should be ok with the neuspeed bar. also with the beaks kit, you will only need to drill 1 hole on each side, very simple and straigh forward, the directions tell you everything you need. just make sure that your lca's have mounting points for your endlinks. the 22mm itr rear sway bar is one of the best suspension additions that i have added to my hatch and would highly recommend picking one up. wil is the man and gives great customer service
here is a pic of my old dc rear tie bar setup w/beaks kit...
dark pic, but here is my new benen tie bar setup w/beaks kit
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leb_CRX »</TD></TR><TR><TD CLASS="quote">I got hte S/T rear sway on my ek, if you want I can take pics for you and you can see if they interfear with the lower tie bar...I would think they do since they use the same holes, but I can't recall off the top of my head
let me know</TD></TR></TABLE>
can you post a pic or two? im curious how the hardware looks too for the susp. tech ****, since they have to provide all of that sutff since our ek's dont have anything stock...
Personaly if I were to get a rear sway bar I would get the Beaks kit to save my sub frame from tearing. Just my .02 cents.
i had the dc lower on with my st rear sway, and now i am using the emracing rear lower tie with the st sways. http://community.webshots.com/...h.jpg
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">Personaly if I were to get a rear sway bar I would get the Beaks kit to save my sub frame from tearing. Just my .02 cents.</TD></TR></TABLE> i would love to use the beaks subframe kit, BUT, i need to know its compatibility with other brands of swaybar kits. I am not paying 270 for his complete swaybar kit.
Am i right in assuming that the beaks kit also spaces out the bar (aside from its protection factor of the subframe) so that it will clear lower ties?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builthatch »</TD></TR><TR><TD CLASS="quote"> i would love th use the beaks subframe kit, BUT, i need to know its compatibility with other brands of swaybar kits. I am not paying 270 for his complete kit.
Am i right in assuming that the beaks kit also spaces out the bar (aside from its protection factor of the subframe) so that it will clear lower ties? </TD></TR></TABLE>
Not too sure on the lower ties question or the compatibility with other sway bars. But I bet you might be able to find out at the website. http://WWW.beaksproducts.com
If you don't find out there you could always contact their customer service department which is excellent in providing information.
monEmakindave
16
Feb 2, 2011 11:02 AM
jeremy.
25
Dec 15, 2003 06:32 PM
