Car drives better on a near empty fuel tank?
Old Apr 20, 2004 | 04:17 PM
eswaroop2's Avatar
Default Car drives better on a near empty fuel tank?
Hi,
I seem to have come across a funny pattern, my car seems to drive better(more responsive, less hesitation during acceleration) when the fuel tank is close to empty and the fuel light comes on. I am yet to confirm the pattern for sure, but could there be a logical explanation for it?
Old Apr 20, 2004 | 04:23 PM
The_Todd's Avatar
Farts in the shower
Default Re: Car drives better on a near empty fuel tank? (eswaroop2)
Other than the fact the your car weighs a lot less due to not as much gasoline in your tank thus your car doesn't have to move that extra weight.
Old Apr 20, 2004 | 04:28 PM
.bagged's Avatar
Default Re: Car drives better on a near empty fuel tank? (VRDrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">Other than the fact the your car weighs a lot less due to not as much gasoline in your tank thus your car doesn't have to move that extra weight.
hahahahahahaahahahah.....thanks MR. Wizard..hahahahahahhaha
Old Apr 20, 2004 | 04:31 PM
eswaroop2's Avatar
Well, it feels at least a thousand pounds lighter. Any better explanation to account for the rest of the performance loss ?
Old Apr 20, 2004 | 04:43 PM
Obsidian's Avatar
What was stated earlier about the weight loss is true. Why don't you believe him? Think of it this way.
Gasoline is a liquid which is heavy. Slightly lighter than water but heavy still. Good example is to take a gallon of water. Now take about 14 of those babies and there you go.
Simply less weight to pull because of it being a four cylinder which means less torque than say a V-6. We might be able to put out more HP eventually but most V-6's will still have more torque.
Yes I do know there are frickin exceptions!
And that is why your car feels faster when it has an empty tank.
One thing to think about, was your car cold when you noticed this. A cold engine likes to pull harder when pushed because it is cold and gets better air and such, not to mention more fuel. Just remember that racing around on a cold engine tears it up much quicker.
Old Apr 20, 2004 | 04:50 PM
The_Todd's Avatar
Farts in the shower
Default Re: Car drives better on a near empty fuel tank? (Obsidian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eswaroop2 &raquo;</TD></TR><TR><TD CLASS="quote">Well, it feels at least a thousand pounds lighter. Any better explanation to account for the rest of the performance loss ?</TD></TR></TABLE>
I really am not making it up...nor bullshitting you.
it takes hp and tq to move that weight, with less weight it will be faster.
Old Apr 20, 2004 | 04:51 PM
P!cKl3$'s Avatar
Wow this situation is funny to me, because usually the exact opposite happens when the tank is low on fuel. Usually the car won't respond as well to an empty tank because the fuel pump can't get a full gulp anymore. Think of it like when you are drinking pop through a straw and it's almost empty, sure you still get some moisture coming into your mouth but not a heavy flow as before. Well congrats on the good outcome from usually a negative situation, but I highly suggest not continuing to do this over a long period of time, unless you are ready to replace your fuel pump in the near future. Just my $0.02
~P!cKl3$~
Old Apr 20, 2004 | 04:52 PM
Mike813's Avatar
same feeling when fat girls get out your car... feels light as a feather
Old Apr 20, 2004 | 05:47 PM
eswaroop's Avatar
Default Re: Car drives better on a near empty fuel tank? (Mike813)
17 * 3.78 litres = 68 pounds, you ppl are saying that by adding around a 100 pounds, the driving charecteristics are changing? Maybe there would be a difference, but it drives worse with just me and a full tank than 4 people and an empty tank. It really drives shitty. And it was not like this before.
Old Apr 20, 2004 | 05:54 PM
.bagged's Avatar
Default Re: Car drives better on a near empty fuel tank? (eswaroop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eswaroop &raquo;</TD></TR><TR><TD CLASS="quote">17 * 3.78 litres = 68 pounds, you ppl are saying that by adding around a 100 pounds, the driving charecteristics are changing? Maybe there would be a difference, but it drives worse with just me and a full tank than 4 people and an empty tank. It really drives shitty. And it was not like this before. </TD></TR></TABLE>
OK now we are getting somewhere..That is the info that we needed at the start
I have no idea why
Old Apr 20, 2004 | 06:08 PM
whoa its len 2's Avatar
Default Re: Car drives better on a near empty fuel tank? (baGged93aCcord)
Gasoline in your tank helps cool down the fuel pump. With low gas levels your fuel pump is exposed above the gas. The fuel pump will heat up quicker and this sorta helps shorten its life span. With a full tank the fuel pump is fully submerged and the gas helps cool it down especially in the cold mornings. After long driving periods the gas in the tank isnt cool anymore, its sorta warm/room temperatue like... this is a reason why your car doesnt run as good when youve been driving around for awhile.
Also, for those who never fill up all the way when getting gas... your leaving oxygen in the tank. On cold mornings "dew" can build up on the sides of the walls in the tank that arent submerged. Dew can grow mold and such in your tank. Before you know it... you have a monster in your gas tank waiting for that special day to come out and eat you during your next fill up.
Old Apr 20, 2004 | 07:01 PM
Heat's Avatar
Default Re: Car drives better on a near empty fuel tank? (whoaitslen2)
If this was happening to me, I'd try changing the fuel filter first. I dunno if it'll do anything, but it is involved with your gasoline, and is cheap to replace.
Old Apr 20, 2004 | 07:19 PM
eswaroop's Avatar
Default Re: Car drives better on a near empty fuel tank? (Heat)
The fuel filter is as clean as new. I checked that out.
Old Apr 20, 2004 | 07:20 PM
eswaroop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoaitslen2 &raquo;</TD></TR><TR><TD CLASS="quote">Gasoline in your tank helps cool down the fuel pump. With low gas levels your fuel pump is exposed above the gas. The fuel pump will heat up quicker and this sorta helps shorten its life span. With a full tank the fuel pump is fully submerged and the gas helps cool it down especially in the cold mornings. After long driving periods the gas in the tank isnt cool anymore, its sorta warm/room temperatue like... this is a reason why your car doesnt run as good when youve been driving around for awhile.
Also, for those who never fill up all the way when getting gas... your leaving oxygen in the tank. On cold mornings "dew" can build up on the sides of the walls in the tank that arent submerged. Dew can grow mold and such in your tank. Before you know it... you have a monster in your gas tank waiting for that special day to come out and eat you during your next fill up. </TD></TR></TABLE>
But according to your explanation, my car should run worse when it is close to empty right?
Old Apr 20, 2004 | 07:25 PM
accordselux's Avatar
Me Gusta History
Well...
Despite how great your gas is, there's still gonna be **** in it. And **** settles. Perhaps you're going to lose it cause all the **** is congregating at the bottom of your tank, and with the low amount of fuel your getting that sucked in your pump?
I see you've checked your fuel filter though....hmmm.
Old Apr 20, 2004 | 07:29 PM
eswaroop's Avatar
Default Re: Car drives better on a near empty fuel tank? (accordselux)
My fuel tank looks like new, there was not a speck of dust in it, (until I actually opened up the fuel pump, and a couple of flakes of dust fell in.), but the problem has been there before the open up.
Old Apr 20, 2004 | 07:30 PM
But according to your explanation, my car should run worse when it is close to empty right?</TD></TR></TABLE>
I didnt say if it will run better or not. It should run better because its not heavy but its also heating up the fuel pump. That causes it to stress out a bit more than normal but its not gonna seize up the motor or anything haha.
Old Apr 21, 2004 | 05:14 AM
eswaroop's Avatar
ok,
So what would actually make it run better? other than the weight loss factor?
Old Apr 21, 2004 | 12:36 PM
jfastman's Avatar
Less fuel in the tank means hot fuel. The fuel pressure regulator will allow unused fuel to be returned to the tank. Maybe the fuel gets warm enough to atomize better? You may have a totally different problem goin' on here, so get your blinders off and check the basics before you start guessing what's wrong.
Old Apr 21, 2004 | 03:48 PM
accord745's Avatar
i know this doesn't help with your problem, but i have to point out a flaw in your calculations.....
17gal = approx 65 L
assuming the density of gas is about 0.75g/mL, then 65L = 48.75kg = 107.25 lb, not 68lb
Old Apr 21, 2004 | 06:34 PM
eswaroop's Avatar
Default Re: Car drives better on a near empty fuel tank? (accord745)
Thanks, that is right! But the problem remains. Sometimes, the car drives well even on a 3/4th full tank...
Old Apr 22, 2004 | 06:16 AM
TOAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike813 &raquo;</TD></TR><TR><TD CLASS="quote">same feeling when fat girls get out your car... feels light as a feather </TD></TR></TABLE>bahaha
Old Apr 22, 2004 | 07:40 AM
-RedneckDave-'s Avatar
Working
Default Re: Car drives better on a near empty fuel tank? (TOAB)
Well since a gallon of water equals 8 pounds and gas is slightly lighter then you could probably say it would be around 6-7 lbs/gal. and since 7 pounds of weight removed is equivelent to 1 horsepower then you can see where the feeling of extra power comes from. But what you said about the car feeling better with more people in the car is probably not about actual performance but has to do with your suspension and when the car is full it is really stiff cause it is weighed down, and seems to respond better. This probably does not have anything to do with the gas level. Just a little to think about
Old Apr 22, 2004 | 11:01 AM
eswaroop's Avatar
Default Re: Car drives better on a near empty fuel tank? (01accordv6)
Ok,
I must maybe rephrase my question. Other than the reduction in weight, could there be some factor which might make it drive better with less fuel in the tank?
Like maybe, pressure buildup due to vapors in the tank which might offset any pressure loss, hotter fuel or something of that sort?
( there would be less chance of a vapor buildup in a full tank right..)
anth2k4
Mar 11, 2009 05:57 AM
ekim952522000
13
Mar 31, 2006 05:51 AM
Power Rev Racing
12
Nov 25, 2005 04:18 PM
HapaHaole
11
Feb 16, 2004 06:04 PM
