smell gas inside the car.. what could it be and how can i fix it?
Old Apr 20, 2004 | 03:54 PM
hadehatch's Avatar
Default smell gas inside the car.. what could it be and how can i fix it?
Sometimes when im driving around I smell gas inside the car... Its way worst when someone sits in the back.. could it be the seal for the gas pump under the seat?? if so will some silicone do the trick??
its really annoying and i always have to drive with the windows down.. (also because i have a stupid exhaust leak) but i can tell the difference between the two..
any feedback is appreciated...
Old Apr 20, 2004 | 04:07 PM
Dacalac's Avatar
Default Re: smell gas inside the car.. what could it be and how can i fix it? (hadehatch)
how well is your catalytic converter? I know sometimes that can be a problem and stink up the car.
Old Apr 20, 2004 | 04:57 PM
daver's Avatar
well, i know for a fact that the fuel lines in the 4g civic and the 2g integra are inside the car (and i assume the 5g, but i havn't checked), you may have popped a leak perhaps.
Also, the fuel pump should be accessible from under the rear seat in the 5g (so i'm told), check it out.
d
Old Apr 20, 2004 | 05:16 PM
Urban Camo's Avatar
i dont believe that the fuel lines are inside the car in a 5g but im not positive, i would check the pump gasket or even check under the hood for any fuel leaks from injectors or filter
Old Apr 20, 2004 | 05:30 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: smell gas inside the car.. what could it be and how can i fix it? (Southtownracing)
for the eg the fuel lines run under the car . now i know that for a fact. but still u are not saying what yr car u have. but if u say its worse in the back seat then pull up the seat and see if its leaking
Old Apr 20, 2004 | 05:47 PM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
Default Re: smell gas inside the car.. what could it be and how can i fix it? (streetdreams02)
Have you checked under the car for puddles of gas? My accord had a bad gas leak and the car smelled like ***. Jack up the car and follow the fuel line from the gas tank to the engine.
PS. If it's dark.... dont use a lighter for light
Old Apr 20, 2004 | 08:32 PM
hadehatch's Avatar
Default Re: smell gas inside the car.. what could it be and how can i fix it? (92prelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92prelude &raquo;</TD></TR><TR><TD CLASS="quote">
PS. If it's dark.... dont use a lighter for light </TD></TR></TABLE>
LOL thanks for the tip.. Theres no puddle.. im assuming its the seal for the pump.. when someone sits back there it becomes more noticable.. also when gas splashes around the tank you can get a nice whiff..
I hope its not from under the hood.. i didnt notice any stains from dried up fuel.. and we checked for leaks when we dropped the motor in.. doesnt hurt to make sure though..
oh yea.. the fuel lines are under the car.. thanks
Old Apr 20, 2004 | 08:51 PM
stockegsix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadehatch &raquo;</TD></TR><TR><TD CLASS="quote">
any feedback is appreciated... </TD></TR></TABLE>
check your fuel rail, might have a tiny leak.
Old Apr 20, 2004 | 09:44 PM
NotUrAvgSi's Avatar
i had the same problem. You should check your fuel injector seals maybe they are bad and gas is dripping from the fuel rail onto your hot manifold and the you get the nasty *** smell in your car. Gave me a headache and a sour throught for a few days it sucked ***.
domrw
Honda Civic (2001 - 2005)
10
Mar 2, 2017 06:40 AM
digitalvice
Mar 26, 2013 02:42 PM
FJBB6
Oct 12, 2009 05:35 PM
alfee
Jan 13, 2005 06:25 PM
90SICRX
May 20, 2004 03:34 PM
