Indiglo gauges on 94-95 accord
Old Apr 20, 2004 | 10:35 AM
Buitrex's Avatar
Default Indiglo gauges on 94-95 accord
Can some body tell me what the procedure on putting indiglo gauges on a accord or where I can download or see installation instructions?
Thnx for ur help
Old Apr 20, 2004 | 11:20 AM
ForceThis!'s Avatar
Default Re: Indiglo gauges on 94-95 accord (Buitrex)
remove the center console and the cruise or dimmer (n iforget which of those). there are two bolts holding on the a/c console under the dash over the center console. there is a bolt under the cruise/dim switch and two in the guage window. pull the a/c / guage console and swing it up onto the dash, remove the guage cluster. slip the indis OVER the needles, don't remove them. trim carefully where necessary. wire the guages in with your ignition, not the radio, indiglos hum. drop the indi dim switch behind the knee bolster. replace everything.
jaykav99
Jun 8, 2006 06:40 AM
DaWorm
Feb 21, 2004 10:35 AM
crx_ef8
Sep 6, 2003 06:08 PM
iwishiwereajap
Jan 19, 2003 05:47 PM
