ProLite or StreetLite Flywheel??
Old Apr 20, 2004 | 02:49 AM
B00ST2nR's Avatar
Default ProLite or StreetLite Flywheel??
Next mod I will purchase is a Flywheel. I'm lookin into ACT XACT Flywheels, and here are the two options.
ProLite - for road racing applications and very quick throttle response
Weight: 8.8lbs
or
StreetLite - for street and drag racing vehicles which may require more inertia.
Weight: 12.5lbs
Which one would be better for my setup? (click the signature to see my setup)
Old Apr 20, 2004 | 02:52 AM
IntEGNYC's Avatar
Default Re: ProLite or StreetLite Flywheel?? (Skunk2nR)
i have a streetlight waiting to be installed.
Everyone goes with the 8 pounder but i sought a mild upgrade over stock so i went with the 12.
Old Apr 20, 2004 | 04:53 AM
IN VTEC's Avatar
Prolite. It's not hard at all to drive on.
Old Apr 20, 2004 | 05:11 AM
JDubya's Avatar
Default Re: ProLite or StreetLite Flywheel?? (IN VTEC)
how about for turbo, does it make much of a difference?
Old Apr 20, 2004 | 05:15 AM
m R g S r's Avatar
Default Re: ProLite or StreetLite Flywheel?? (ALL MOTOR LS)
I just ordered the streetlite with an action 2md clutch.
Old Apr 20, 2004 | 06:35 AM
patdemps's Avatar
Default Re: ProLite or StreetLite Flywheel?? (m R g S r)
I suggest prolite.
But either way you'll love the difference.
I went with 7.5lb Fidanza for my setup.
.....by the way. how long until you install the custom header/cat, etc. and get that baby dyno'd?
Old Apr 20, 2004 | 06:44 AM
Cjsls's Avatar
Default Re: ProLite or StreetLite Flywheel?? (patdemps)
yea, i have the 12lb streetlite and wish i would of bought the prolite to begin with.
Old Apr 20, 2004 | 07:48 AM
IntEGNYC's Avatar
Default Re: ProLite or StreetLite Flywheel?? (CjMtrSports)
why, is there a world of difference between the 4 pounds?
Old Apr 20, 2004 | 08:10 AM
riceball777's Avatar
i have the pro light and i love it. rpms drop fast as hell. so you have to shift much faster. and its much easyer to stall if your not use to it. before with the stock flywheel if you let the idel drop under normal (750rpm) and hit the clutch the car will just shake a lil and the idel will just bounce back up. but not with the lighter flywheel. if you ever let the idel drop just a lil and hit the clutch the car will just die the idel will not come back up. but you will get use to it over time.
with a lighter flywheel it is harder to get the car moving from a stop and over all drivability will suffer
Modified by riceball777 at 7:26 PM 4/20/2004
Old Apr 20, 2004 | 08:47 AM
IntEGNYC's Avatar
Default Re: ProLite or StreetLite Flywheel?? (riceball777)
just seems like a lot of work...
wouldnt make for a good cruising car.
Im looking to make mine easier for long cruises and not a short distance pavent pounder. i think i made the right choice on the 12 lbs for my driving. but some others might like the faster reving.
Old Apr 20, 2004 | 09:37 AM
Retroo's Avatar
Default Re: ProLite or StreetLite Flywheel?? (IntEGNYC)
go with the fidanza flywheel, 7 lbs...
Old Apr 20, 2004 | 09:46 AM
nolexforever's Avatar
NA setup for auto-x, road racing...i'd go with the lighter flywheel, the prolite.
drag racing, and/or turbo cars should NOT go with the lighter flywheel since you will need the inertia from the flywheel for the holeshot.
Old Apr 20, 2004 | 10:13 AM
spoolindc2's Avatar
I just got my pro lite and ACT clutch put on... still breaking it in but i love it. Prolite
Old Apr 20, 2004 | 10:38 AM
quikB18B's Avatar
Default Re: (rjride1020)
For your plans with the car I would go with the Prolite.
Old Apr 20, 2004 | 10:50 AM
JDM_Risa's Avatar
Default Re: (quikB18B)
i have a prolite in my car i rarely stall only when i get lazy..when i was all motor i used the same prolite flywheel works like a charmed with skunk stage 2 and TYpe R head and DTR header.........revs were much quicker
used for 1 year no problems yet
Old Apr 20, 2004 | 03:19 PM
B00ST2nR's Avatar
Alright... ProLite it is. I want my car to rev faster... which ultimately means it will have faster acceleration, correct?
Old Apr 20, 2004 | 03:47 PM
Kendall's Avatar
I went with Fidanza.
Old Apr 20, 2004 | 04:29 PM
TeamSTEALTH GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2nR &raquo;</TD></TR><TR><TD CLASS="quote">which ultimately means it will have faster acceleration, correct?</TD></TR></TABLE>
yes...
Prolite
Old Apr 20, 2004 | 04:42 PM
Ti3d in's Avatar
Default Re: ProLite or StreetLite Flywheel?? (TeamSTEALTH GSR)
Prolite is more tended towards one purpose, like road racing auto-x. Streetlite is overall, pretty okay at all purposes. I don't have either, but there's my opinion
Old Apr 20, 2004 | 05:04 PM
Default Re: ProLite or StreetLite Flywheel?? (Ti3d in)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ti3d in &raquo;</TD></TR><TR><TD CLASS="quote">Prolite is more tended towards one purpose, like road racing auto-x. Streetlite is overall, pretty okay at all purposes. I don't have either, but there's my opinion </TD></TR></TABLE>
how is that? are u saying that ull benifit with a prolite in roadracing but not in drag?
i dont have a problem with rpms droping fast between shift with my prolite... nothing but quicker revs....Prolite
Old Apr 20, 2004 | 05:14 PM
Kusai.Nihonjin.Desu's Avatar
I had the 12 pounder(with HDSS) in my old hatch set-up...it was most excellent.
I'm about to purchase the 9 pounder for the GSR(with HDSS)...we shall see.
Old Apr 20, 2004 | 05:15 PM
Kendall's Avatar
I'm convinced that ACT sells two different flywheels specifically for marketing purposes. It's proven that a lighter flywheel will benefit acceleration, however rumors and hearsay often combat the truth. ACT just figured it could cash out on everyone, regardless of what they believe.
Old Apr 20, 2004 | 05:25 PM
Big Teggie's Avatar
Prolite, I am a lightweight part kinda guy
Anyways, here is a small Streetlite review I did http://m24x.zeroforum.com/zerothread?id=467
Old Apr 20, 2004 | 05:35 PM
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">I'm convinced that ACT sells two different flywheels specifically for marketing purposes. It's proven that a lighter flywheel will benefit acceleration, however rumors and hearsay often combat the truth. ACT just figured it could cash out on everyone, regardless of what they believe.</TD></TR></TABLE>
Hey, smart business.
Old Apr 20, 2004 | 05:39 PM
GSRontheBottle's Avatar
streetlite
