What Anti-Freeze/Coolant do you guys use?
Old Apr 19, 2004 | 11:42 PM
5spdIntegra's Avatar
Default What Anti-Freeze/Coolant do you guys use?
Well it's time for me to change my Anti-Freeze/Coolant now that summer is just around the corner and the drag strip is open. Do you guys suggest anything besides OEM Anti-Freeze/Coolant?
Thanks for the help.
Old Apr 19, 2004 | 11:50 PM
Two_K Si's Avatar
Default Re: What Anti-Freeze/Coolant do you guys use? (5spdIntegra)
http://www.evanscooling.com/index2.html or OEM only
Old Apr 20, 2004 | 08:20 AM
Default Re: What Anti-Freeze/Coolant do you guys use? (Two_K Si)
Anyone else?
Old Apr 20, 2004 | 08:30 AM
Honda Hick's Avatar
I've always used whatever is on sale . If you aren't boosting and creating alot of heat it doesn't really matter.
Old Apr 20, 2004 | 08:35 AM
IVI's Avatar
IVI
Default Re: What Anti-Freeze/Coolant do you guys use? (Honda Hick)
anything, prestone is fine.
MightyMouseTech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Hick &raquo;</TD></TR><TR><TD CLASS="quote">I've always used whatever is on sale . If you aren't boosting and creating alot of heat it doesn't really matter.</TD></TR></TABLE>
I would love to see inside your water jacket....
I strictly use Honda Type 2 in all my cars. Except race cars (real race cars, not drag cars ) which are required to run water only.
Old Apr 20, 2004 | 08:40 AM
Audi A4's Avatar
Default Re: What Anti-Freeze/Coolant do you guys use? (MightyMouseTech)
I use prestone.. even when boosting boosted 2 years
Old Apr 20, 2004 | 10:40 AM
dip-set's Avatar
Default Re: What Anti-Freeze/Coolant do you guys use? (DRAG lll INTEGRA)
yes sir prestone here,the already 50/50 mixed version...
Old Apr 20, 2004 | 10:46 AM
PolySquared's Avatar
Default Re: What Anti-Freeze/Coolant do you guys use? (b18b-se)
i'm using prestone, boosting 10psi with a/c.
Old Apr 20, 2004 | 11:40 AM
Lord Helmet's Avatar
prestone here used it in 130 degrees and -10 degrees tempertures. no problems at all.
Old Apr 20, 2004 | 12:21 PM
Default Re: What Anti-Freeze/Coolant do you guys use? (sleeperciv)
Um, the type of coolant you use really has no affect on how well it cools. For best cooling, you actually want NO coolant and run straight water (with a little bit of redline water weter thrown in) Coolant mainly prevents freezing/boiling and prevents corrosion of all of the items the coolant touches. Adding coolant to the system actually reduces its heat transfer properties. Better coolants will prevent damage by resisting the formation of acid in the cooling system. (do you know what your coolant pH is?) I recommend coolant flushes at a pH of 8.0 and lower. Less expensive coolants are not far from that brand new. Honda Type 2 will take YEARS to get there, although, I flush mine every year. (kind of annoying because I have 7 hondas/acuras) Prestone isn't bad, but there is better out there.
Old Apr 20, 2004 | 12:45 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">... For best cooling, you actually want NO coolant and run straight water...</TD></TR></TABLE>Just to be a ***** about terminology, the plain water IS the coolant. Anti-freeze is what you mean. Plain water makes a better coolant than anti-freeze. But it's no good if it freezes or boils...
The business about pH depends on what corrosion package you're talking about. The American style has more silicates and moderate amount of phosphates. Asian style is high on phosphates and no silicates. European style has no phosphates and no silicates. DexCool uses carboxylic acids instead and is phosphate and silicate free. Hybrid style has carboxylic acids and low levels of silicates but no phosphates. I bet their pH doesn't ALL behave the same way. Especially DexCool.
Old Apr 20, 2004 | 01:15 PM
Honda Hick's Avatar
The inside of the water jackets are fine. As long as you change it every 40k or so there shouldn't be any problems. I personally change it probably every 15k-20k to keep **** from building up in there, but the brand isn't going to do anything. When I bought my car at 175k the previous owner proudly stated that they "change the oil regularly every 25,000 miles" , lol (I was plannin on rebuilding the engine anyway). I can only imagine how often the coolant was changed, and it was fine when I opened the engine up. Coolant isn't exactly brain surgery.
Old Apr 20, 2004 | 01:23 PM
Default Re: What Anti-Freeze/Coolant do you guys use? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">The business about pH depends on what corrosion package you're talking about. The American style has more silicates and moderate amount of phosphates. </TD></TR></TABLE>
I didn't think that there are any name brand coolants that still contain any silicates, no matter what continent.
spender1326's Avatar
If you really want better cooling, try WaterWetter by Redline. It works. I think it increases specific heat. But anyways, it just takes more heat away from the heat source, namely the engine. A friend of mine has a 7.4 liter GMC truck, when he climbs hills before water wetter he would pass his center line on the water temp meter, and after it stays in the middle. Same principle should apply when racing our little 1.8L 4 bangers.
Old Apr 20, 2004 | 01:27 PM
Default Re: What Anti-Freeze/Coolant do you guys use? (spender1326)
It reduces the surface tension of the coolant. Basically it is water softener.
Old Apr 20, 2004 | 01:28 PM
JL 74's Avatar
the Honda brand. I got a coupon for it for like $7.99
Old Apr 20, 2004 | 02:44 PM
xplanetearth420x's Avatar
Default Re: What Anti-Freeze/Coolant do you guys use? (JL 74)
prestone
Old Apr 20, 2004 | 04:17 PM
nyo91's Avatar
Default Re: What Anti-Freeze/Coolant do you guys use? (xplanetearth420x)
oem honda fliuds
Old Apr 20, 2004 | 04:25 PM
Default Re: What Anti-Freeze/Coolant do you guys use? (nyo91)
Ok Team Integra says to use half water half OEM anti freeze. Should I do this using Prestone as well?
Modified by 5spdIntegra at 5:46 PM 4/20/2004
Old Apr 21, 2004 | 04:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5spdIntegra &raquo;</TD></TR><TR><TD CLASS="quote">Ok Team Integra says to use half water half OEM anti freeze. Should I do this using Prestone as well?
Modified by 5spdIntegra at 5:46 PM 4/20/2004</TD></TR></TABLE>
Depends on which OEM. Honda Type 1 you have to mix (50/50 recommended on the bottle, I mix it 60/40 water/coolant personally) The new Type 2 comes premixed, you can just dump it in. I also like the smell of Type 2, smells like play-doh Although, you can buy Type 2 in pails that is not premixed if you REALLY want to mix it yourself.
Old Apr 21, 2004 | 05:23 AM
R.S.'s Avatar
i use the honda pre-mixed coolent....
Old Apr 21, 2004 | 09:23 AM
Echo7847's Avatar
Default Re: What Anti-Freeze/Coolant do you guys use? (R-Spec)
I use the oem Type-II
Old Apr 21, 2004 | 11:50 AM
Default Re: What Anti-Freeze/Coolant do you guys use? (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">I use the oem Type-II</TD></TR></TABLE>
Whats the price on that?
Old Apr 22, 2004 | 06:47 PM
Echo7847's Avatar
Idk I think around $8 a gallon or something. Its about 6 after my discount so around 8-9.
