Need help on B20 Swap- ***Pics inside***
Old Apr 19, 2004 | 11:03 PM
XtremeCarTuner's Avatar
Default Need help on B20 Swap- ***Pics inside***
Hey guys. I'm removing my LS engine from my car and installing a b20b engine. I ran into a problem with my swap. There is a sensor located near the crank pulley and there is nothing like this on the b20b motor....
btw i took these pics on my cell phone
Here....
These pics are from the b18b block. Notice those wires and the connector.
Now the problem:
*B20B*
Does anyone know how to fix this problem???
Any help is appreciated.
thanks guys
Old Apr 20, 2004 | 12:55 AM
MR Dan's Avatar
66.116.69.217
Default Re: Need help on B20 Swap- ***Pics inside*** (XtremeCarTuner)
ez fix, at this stage, might as well swap to a Vtec oil pump and water pump with the Vtec timing belt. The GSR or Type R oil pump will have a spot for that sensor.
Old Apr 20, 2004 | 07:09 AM
revhigh89's Avatar
Default Re: Need help on B20 Swap- ***Pics inside*** (DP24)
u are absolutely right
Old Apr 20, 2004 | 08:16 AM
mr.beeks's Avatar
Default Re: Need help on B20 Swap- ***Pics inside*** (Sold My Teg)
well if you are running on obd2 you will need it
and like they said use the type r oil pump
but if you are going to use an obd1 ecu you dont need it...
and that sensor is your crank position sensor..
Old Apr 20, 2004 | 11:09 PM
Default Re: Need help on B20 Swap- ***Pics inside*** (mr.beeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">well if you are running on obd2 you will need it
and that sensor is your crank position sensor..</TD></TR></TABLE>
I removed my b16 oil pump and placed it into my b20. Wasn't that much of a challenge, but other than that my oil pump is pretty new.
Thanks for clearing that out for me
Old Apr 21, 2004 | 02:38 AM
GZR4DR's Avatar
On OBD1 motors its located in the distributor. Good news about B20 motors is they utilize the same oil pump as the vtec motors (efficiency), however I'm sure you already knew this.
miguel aguirre
Jun 4, 2016 11:23 PM
Bwhit12
Dec 31, 2011 11:52 AM
RA122324
227
Oct 27, 2005 01:21 PM
Rob!
89
Feb 23, 2004 10:36 PM
Dokta
Jul 28, 2002 09:45 AM
