Will i ping?
Will i ping with b16 pistons ping on premium gas with my 95gsr? How much room do i got? Will i be safe with a spoon head gasket too? Or shoudl i just go OEM? I'm about to buy some b16 pistons and i just want to double check that they wont bump my compressino up too high. Thanks guys
also, what size rings will i need? how wil they mount up to b18 stock rods?? ty
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rough_draft »</TD></TR><TR><TD CLASS="quote">nice, aer you tuned or did you just swap em in and go? What is ur set up? Thanks man</TD></TR></TABLE>
He is tuned. But having problems right now. Check out his thread above yours. He went to the dyno and didn't have the numbers he expected. bad day at the dyno its titled.
I used b16 piston rings and oem head gasket, stock rods if you leave your head alone you should be at about 11.4:1 compression
