(poll)what size slicks do you use?
Old Apr 19, 2004 | 08:42 PM
londa hover's Avatar
Default (poll)what size slicks do you use?
vote witch size slicks you use. and post what kind of car and hp, tq you have. and also what size slicks would be best on a gsr w/195whp 137tq
Old Apr 19, 2004 | 10:05 PM
LUCKYDRAGSTA's Avatar
Default Re: (poll)what size slicks do you use? (londa hover)
lots of different factors come to play when choosing a slick size.like whats the weight of the car what final drive and tranny that your running. but for your horsepower range i would say any 22 inch slick would do.
Old Apr 19, 2004 | 10:17 PM
ExospeedAMcrx's Avatar
thats correct:
Gearing, Final Drive, Rim size, HP, all play a factor in choosing the right slick size.
In your case though, I assume you have a basic GSR setup(GSR trans and Motor), a 22x8x13 will be a good size for now and as you step up into the low 200s. once you get into 230+, theres 23" tall slicks and different widths on 24.5" slicks.
Old Apr 20, 2004 | 10:34 AM
Default Re: (exospeedAMcrx)
i got a b16 tranny with a phantom lsd and ls 5th gear and my car weighs 2285lbs. right know i have 20/8/14 but personaly i think 22/8.5/13 would be better on my car what do you guys think? will 20/8/14 do the job?
Old Apr 20, 2004 | 10:37 AM
Default Re: (londa hover)
and also i use nitrous but not in first gear so thats way i put 195whp 137tq w/n2o i dyno'd at 244whp 178tq w/ 55shot
Old Apr 20, 2004 | 12:26 PM
Blitzkrieg's Avatar
None of the above 26x8x15
Old Apr 20, 2004 | 05:48 PM
can anyone answer my question
Old Apr 20, 2004 | 08:18 PM
seems like a 23x8x13 would be the best compromise for you.
you have the nitrous so you need a bit more Bite than the 22", but then you dont have a great amount of HP either to move to a 24". so the 23" tall seems to be the best overall.
Old Apr 21, 2004 | 11:13 AM
ya but i wont be using nitrous when launching i only use it in every gear but 1st.
Old Apr 21, 2004 | 11:57 AM
12secB18acivic's Avatar
I run 24.5x8.5x13 MandH with my 2 liter LsVtec All Motor with the 4.7 final drive
Old Apr 21, 2004 | 01:28 PM
Default Re: (poll)what size slicks do you use? (12secB18acivic)
what size slicks should a stock integra type-r use?
Old Apr 21, 2004 | 01:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by londa hover &raquo;</TD></TR><TR><TD CLASS="quote">what size slicks should a stock integra type-r use?</TD></TR></TABLE>
22x8x13 MandH slicks
Old Apr 21, 2004 | 01:44 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">Gearing, Final Drive, Rim size, HP, all play a factor in choosing the right slick size.</TD></TR></TABLE>
cable jdm s1 tranny, 4.40 fd, 13" rim(lenzos), 182/140, what would be my ideal slick size? would a 22x8x13 with a 8500rpm redline be the one, or will the 23x8x13 be the better choice? BTWright now i'm using a M&H 13" dot drag radial tire, to finish the 1/4 mile in 4th gear at about 7-7500 rpms. if i change from that tire to a slick, will i need to touch fith gear?
Old Apr 21, 2004 | 01:59 PM
AMS MIKE's Avatar
Default Re: (smokey2.0)
26x8.5x15
Old May 3, 2004 | 04:02 PM
GSRswapandslow.
Guest
Posts: n/a
i run 24.5/8/13 MT's on my weld magnums for my 2.1L ITR engine (n/a)
Old May 4, 2004 | 04:32 AM
b18psi's Avatar
What do you guys use for the 13 inch wheels? I am looking at slicks but am using an OEM honda wheel (maybe a 15 inch).
Old May 4, 2004 | 04:55 AM
GSRswapandslow.
Guest
Posts: n/a
Default Re: (b18psi)
Old May 4, 2004 | 06:04 AM
99lspwr's Avatar
Default Re: (GSRswapandslow.)
I use an m&h 24x9.2x15.....These have been working out really well...
Old May 4, 2004 | 07:24 AM
b18psi's Avatar
Were do some of you buy the MandH slicks? I have found a lot of places that sell Mickey Thompson but not MandH.
Old May 4, 2004 | 07:33 AM
b18psi's Avatar
Also, I am not sure if the 24x9x15 will fit on my 6.5 inch wide integra alloy. What is the widest that would fit?
Old May 4, 2004 | 07:34 AM
GSRswapandslow.
Guest
Posts: n/a
just ask John....
he's a member!
M&H are the best by far....and the customer service is like NO OTHER COMPANY!!!!
i'll be swapping to them after my MTs are gone
Old May 4, 2004 | 07:55 AM
MilanoFury's Avatar
Can you put a 24x8x13 on stock finders?
Old May 4, 2004 | 08:48 AM
GSRswapandslow.
Guest
Posts: n/a
look up...that's 24.5x8x13
Old May 4, 2004 | 09:16 AM
b18psi's Avatar
I am running 15 inch wheels.
Old May 4, 2004 | 12:10 PM
b18psi's Avatar
I think I am going to run the 22-8-15.
