JDM OEM Stanley Sidemarkers
Old Apr 19, 2004 | 08:24 PM
ChopstiX's Avatar
Default JDM OEM Stanley Sidemarkers
Hi I was wondering if anyone has some jdm stanley sidemarkers? if so does anyone know where i can get a template for the install?
the sidemakers i got are like this..
Old Apr 19, 2004 | 08:57 PM
ru2slo's Avatar
Default Re: JDM OEM Stanley Sidemarkers (ChopstiX)
those are gonna look sweet. I've been thinking about getting some for my DA.. but iono, lots of people have them nowadays.. they will look nice on that blue.. if thats ur color.
Old Apr 19, 2004 | 09:01 PM
G2Ijth's Avatar
Default Re: JDM OEM Stanley Sidemarkers (ru2slo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ru2slo &raquo;</TD></TR><TR><TD CLASS="quote">lots of people have them nowadays.. </TD></TR></TABLE>
...the very reason I wont ever have them.
Old Apr 19, 2004 | 09:18 PM
ChopstiX's Avatar
yea i have supersonic blue pearl.. i just need template!
Old Apr 19, 2004 | 09:43 PM
diM`'s Avatar
Default Re: (ChopstiX)
patrickgsr94 - search for him.. he did a thread on it
Old Apr 19, 2004 | 10:24 PM
Dc2 Powered's Avatar
serach bro i did once and came up with 2 or 3 DIY with messurments and everything H-T
Old Apr 19, 2004 | 11:02 PM
95gsrturbo's Avatar
Default Re: (Speedin Type R)
all i can find right now for you is this https://honda-tech.com/zerothread?id=819615
there is a template here that i saw once but i never used it... i just measured the inner lenght and width and cut based on that..... cut it small at first (inside the line you draw and trim to fit-- because if you cut just a hair too big you are kinda screwed -- good luck
Old Apr 20, 2004 | 03:31 AM
IntEGNYC's Avatar
Default Re: (95gsrturbo)
i have these.
make your own template. in fact you dont need a template.
measure up on the fenders and use masking tape to mark the cut.
Old May 1, 2004 | 09:29 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: (IntEGNYC)
Hey Tommy, you don't need no stinkin' template! I got a drill and a glue gun!!! hehe! j/k!
Old May 2, 2004 | 02:20 AM
BlackSage's Avatar
I didnt use a template and it was my first time doing it. They are not perfect, but I am happy. All I did was use the pic in the other thread that I stole from Patrick (Thanks ) and brought out the measuring tape. Took me about 5 hours total in the hot *** sun with a drill and a metal file.
Old May 2, 2004 | 05:52 AM
Bl6da9's Avatar
dam dude 5 hours i used a dremel and it took me 30 min to do both sides. I have the JDM fenders for my car but havent put them on till i paint the whole car. I got a piece of paper traced the location and the shape of it and just transfered that to the fenders on my car.
Old May 2, 2004 | 02:27 PM
Xsi's Avatar
Xsi
Are the standard ones clear? Damn, everyone over here is swapping out their orange ones for clears.
Old May 2, 2004 | 03:00 PM
Rishiras's Avatar
I need those but in Clear, exact size and flat type.
I can get you those orange models from Japan for $50
Old May 2, 2004 | 04:59 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">Are the standard ones clear? Damn, everyone over here is swapping out their orange ones for clears.</TD></TR></TABLE>
USDM cars didn't get them (not required here), but I think they are a good safety feature to have. I used to have imitation clear OEM sidemarkers, and they fit horrible, and they looked pretty bad too, as I had painted them orange because I didn't want to shell out the money for OEM. Later I got OEM Stanley ones and they fit 100% better.
What I did was draw my template in AutoCAD and printed it out, so I could make sure it would be the exact size. Then I measured and taped the template to the BACK of the fender (took fenders off, actually one of them was one of my black ones that I had not installed yet), and then I used a knife to cut along the lines of the template, which scored lines into the metal on the inside of the fender. I did this because on my old fenders, I had drawn the pattern on the outside, and then used my metal nibbler from the inside of the fender so that it poked out to the outside, so I could follow the pattern. You kinda have to know how the metal nibbler works to understand this, but it was pulling the metal pieces back towards the inside, and pulling some paint off with it. So this time I wanted to use the metal nibbler on the outside, and stick it thru to the inside of the fender, so the metal piece would be pulled back towards the outside. To do that I had to have the pattern on the inside of the fender.
Here's the template, it's for an EG to correctly place the sidemarker on the fender, but the hole itself is the same for DC's:
Here's the placement for DC's:
Old May 2, 2004 | 05:04 PM
JDMHN8's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
USDM cars didn't get them (not required here), but I think they are a good safety feature to have. </TD></TR></TABLE>
Sidemarkers are indeed required here in the US, but on nearly every Honda for the USDM, they are found in the corner lamps or bumper lenses.
Old May 2, 2004 | 05:47 PM
Community Builder
Default Re: (JDMDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDA9 &raquo;</TD></TR><TR><TD CLASS="quote">
Sidemarkers are indeed required here in the US, but on nearly every Honda for the USDM, they are found in the corner lamps or bumper lenses.</TD></TR></TABLE>
Cars here are required to have turn signals and reflectors on the front corners of the vehicle. European, Australian and Japanese cars are required to have turn signals on the front fenders behind the front wheels.
Old May 2, 2004 | 06:06 PM
IntEGNYC's Avatar
nice work patrick
Old May 2, 2004 | 06:07 PM
jDMJeRk's Avatar
If you go to g2ic.com and go under the teg tips there is a very good walkthrough on how to do it. Probably would work on any car
Old May 2, 2004 | 06:59 PM
G2 Vtec's Avatar
Default Re: (jdmjerk)
Yea i did them on my buddies teg, came out clean. We used Saab 900se sidemarkers, dimensions for cuts were identical of the g2ic thread. Used a dremel, took about 30 min for each side carefully cutting double checking everything every 5 min. Looks solid, cept the saab marker lights seem to be brighter then the jdms, bigger bulbs.
Old May 2, 2004 | 07:21 PM
JDMHN8's Avatar
Cars here are required to have turn signals and reflectors on the front corners of the vehicle. European, Australian and Japanese cars are required to have turn signals on the front fenders behind the front wheels.</TD></TR></TABLE>
That turn signal on the sides of the front and rear corners is the side marker light required by Federal Motor Vehicle Safety Standard 108. There isn't a reason for the corner lights Jap cars come with over here; all the new VWs and BMWs prove that you can leave the sidemarker on the fender and still meet the regulation. All you need is a reflector on the front and rear of the vehicle, the sidemarker can be anywhere ahead of or behind the doors...
Think about it; a turn signal on the side of the car. Sidemarker.
Heres the study the regulation stems from:
http://www.nhtsa.dot.gov/cars/....html
Old May 2, 2004 | 07:33 PM
LSvtec03's Avatar
heres a pic of the jdm sidemarkers installed from the factory. i think its easier to just align them this way than to measure from the crease in the fender.
i know it doesnt look like it in the pic, but the front of the sidemarker really is 90 degrees up from where the crease meets the wheel well. hth
Old May 2, 2004 | 07:41 PM
Community Builder
http://www.nhtsa.dot.gov/cars/....html</TD></TR></TABLE>
umm USDM BMW's and VW's have turn signals on the front corners, which are required, in addition to the side markers on the fenders.
Old May 9, 2004 | 10:39 PM
Turbo'dMex-A-Keen's Avatar
man Pat , dude sure doesnt wanna just shut his hole and llet it be, hahaha
Old May 10, 2004 | 06:15 AM
-iLLuZioN-B18C1's Avatar
mine look just like that. just bought some sidemarkers at store and sprayed them with some orange krylon 'stained glass' and looks perfect.
Old May 10, 2004 | 06:22 AM
xSCTYGx's Avatar
Default Re: JDM OEM Stanley Sidemarkers (G2Ijth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2Ijth &raquo;</TD></TR><TR><TD CLASS="quote">
...the very reason I wont ever have them.</TD></TR></TABLE>
I hate people like that...they won't do something just because everyone else does something. So I have a question for you...why do you have an integra? Everybody and their mom has one. I think people should do things because they want or like doing whatever...
I actually really like the side markers, and say go for it!
