HELP ASAP . I NEED THE LENGTH OF THE TYPE R CAT
Old Oct 30, 2001 | 09:49 AM
PM-Performance's Avatar
Default HELP ASAP . I NEED THE LENGTH OF THE TYPE R CAT
IM GETTING A TEST PIIPE MADE AND DONT HAVE TIME TO JACK IT UP AND MEASURE IT . . . . .
Old Oct 30, 2001 | 10:05 AM
sackdz's Avatar
Default Re: HELP ASAP . I NEED THE LENGTH OF THE TYPE R CAT (itr206)
LoL, I can tell you it's shorter than a Godspeed testpipe (sorry i had to)
I'll post a measurement in a few hours, but sorry don't have it ASAP.
sackdz - who gives Godspeed and will order from him anytime
[Modified by sackdz, 2:06 PM 10/30/2001]
Old Oct 30, 2001 | 10:14 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: HELP ASAP . I NEED THE LENGTH OF THE TYPE R CAT (sackdz)
Instead of starting another topic, I'll ask my question here, which is related to this topic. Hope you don't mind.
Is the length of a JDM header + cat equal to the length of a USDM header +cat?
I guess what I'm trying to find out is, are the length of JDM and USDM b-pipes the same?
Thanks guys.
Old Oct 30, 2001 | 10:35 AM
Default Re: HELP ASAP . I NEED THE LENGTH OF THE TYPE R CAT (Wai)
i also need the distance between bolt holes and stuff , , basically every measurement i could need on the cat to make a test pipe
Old Oct 30, 2001 | 10:48 AM
sackdz's Avatar
If you can wait 2 1/2 hours, I'll measure it all for you when i get home and post it.
sackdz - who just realized the full beauty of end-of-reply 3rd person statements, and ironically the full beauty of the honda-tech itr forum (the way it should be)
Old Oct 30, 2001 | 11:46 AM
thanks, let me knwo .
Old Oct 30, 2001 | 11:47 AM
Big Phat R's Avatar
Thanks guys.
The JDM b-pipe is longer and the cat shorter - but overall length from the header flange should be identical. I have the JDM Mugen B-pipe and Spoon cat jack and it bolts right up to the Spoon 4-2-1 header.
Old Oct 30, 2001 | 01:30 PM
sackdz's Avatar
Here you are:
These pics should give you everything you need to know
The 2 hole flange should be loose and able to slide on the testpipe.
Any q's let me know
sackdz's Avatar
How's that for customer service?
Old Oct 30, 2001 | 01:34 PM
Toda Party's Avatar
Old Oct 30, 2001 | 01:35 PM
sackdz's Avatar
Default Re: HELP ASAP . I NEED THE LENGTH OF THE TYPE R CAT (Toda Party)
Hehe, I'm gettin better with photoshop
Old Oct 30, 2001 | 01:48 PM
DUDE YOU ARE THE FUKING MAN . . . .. YOU EVER NEED ANYTHING LET ME KNOW . . !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
THANKS
Old Oct 30, 2001 | 01:53 PM
on the outlet end, can you get the distance from actuall hole to hole just in case these reatards cant figure it out. thanks, sorry to be a pain
Old Oct 30, 2001 | 03:32 PM
sackdz's Avatar
outlet end (3 hole flange)
from center of bolt hole to center of bolt hole is exactly 3"
You can always drill them out, but have them make the holes a little larger because fit won't be perfect.
Old Oct 31, 2001 | 12:07 AM
kkim's Avatar
question about the using a test pipe... how do you keep the secondary o2 sensor from lighting the engine check light?
Old Oct 31, 2001 | 04:55 AM
sackdz's Avatar
Default Re: HELP ASAP . I NEED THE LENGTH OF THE TYPE R CAT (kkim)
Godspeed sells a testpipe with an O2 bung that has cat material in it to simulate a CC. Mine's been on for a few weeks and no CEL yet. There was a recent thread where someone is trying to sell an O2 simulator, but I can't find it. Also someone mentioned Summit Racing had an O2 simulator as well.
Old Oct 31, 2001 | 05:43 AM
thaks for the info . . . so even if i put in the spot for the o2 , my check engine will come on if i dont have this cell or whatever. . .?
will it hurt my performance.
Old Oct 31, 2001 | 05:51 AM
sackdz's Avatar
No, it won't hurt your performance. Just have to see the CEL on all the time, or take the bulb out. I chose not to because frankly, I'd like to know if something was ever wrong and if it was on all the time i'd never notice. the testpipe is like $125. They have had fitment issues in the past, mine was too long, but I marked it and he cut it to the correctly length quickly no questions asked.
But hey, you can get a carsound cat for $99 and define3tly won't have any problems.
Old Oct 31, 2001 | 05:57 AM
Dropspeed's Avatar
Your moms going to kill you if she finds out you put that dirty cat on her kitchen table
Mattj
[Modified by Dropspeed, 7:44 AM 10/31/2001]
Old Oct 31, 2001 | 06:32 AM
Default Re: HELP ASAP . I NEED THE LENGTH OF THE TYPE R CAT (Dropspeed)
so what exactly should i look for from summit now?, im getting the pipe custom made. and its just pipe what exactly do i need for it not to come on
Old Oct 31, 2001 | 06:36 AM
also what is gods web site, i had it and cant find it anywhere now. . . . i wanna get a jdm 4-1 too. . . do i need a diff size test pipe for that conversion
Old Oct 31, 2001 | 06:47 AM
sackdz's Avatar
http://godspeed.hack.net
No same size, but you will also need a 2.5" donut gasket which he and others sell for $25
Old Oct 31, 2001 | 08:25 AM
kkim's Avatar
Regarding the test pipe with a bung hole.... I have one, but without the cat material in it and it throws the CEL. I've heard that placing a resistor inline to the sensor lead to the ecu would simulate the sensor "hot" value and would "fool" the ECU from throwing the CEL. Any truth to this and if so, anyone know the resistor value to use?
Old Oct 31, 2001 | 08:42 AM
sackdz's Avatar
I was going to do this also, but decided on the easily reversible clean install. I dont' know, the service manual should list acceptable output voltages for the O2 sensor. You could put an ohmeter on the sensor with the car warmed up and running, and see what resistance value would come close. However I've also heard that it fluctuates in a pattern, though I don't know if there is any truth to that.
newport45
Mid-Atlantic (Sales)
Nov 6, 2009 02:57 PM
Mikizzle
Northwest (Sales)
Apr 8, 2006 11:52 AM
Charlie Moua
Mar 22, 2006 05:14 AM
intekragsr
Apr 11, 2005 11:54 PM
