Help! weird problem. heat and idol
Old Apr 19, 2004 | 03:47 PM
ditsboy's Avatar
Default Help! weird problem. heat and idle
I am having problem with my 93 ex 2d. when my car is not moving the heat gauge start to move up.(heating up) but when I start driving again the gauge moves back down to little less than half.(which is normal) I want to know how to fix this problem. even time I fill up the coolent after it heats up, drive it again it heats up again when I go to check the coolent. it's down below min. but I check there is no leak, I don't see any on the ground at least. I didn't realize this problem until I start using my ac last week. please any help will be appreciated thanks,..
Modified by ditsboy at 6:08 AM 4/20/2004
Old Apr 19, 2004 | 03:49 PM
DAguyLS's Avatar
get up under your car and look around the crank, thats where your water pump is...(assuming you have a d-series motor)
if you see alot of dirt and antifreeze, then it's your water pump. and you probably won't see antifreeze on the ground if you just have a slight leak.
hope this helps
Old Apr 19, 2004 | 03:50 PM
DAguyLS's Avatar
oh and i think you meant IDLE....not idol
theazndog
Sep 7, 2009 04:42 PM
3rdgenintegra48
Apr 8, 2008 10:32 AM
TheNanashi
Mar 30, 2003 11:13 AM
FredoTheChimp
Dec 31, 2002 03:48 PM
