Question on Drag III install...downpipe flange...where?
Old Oct 30, 2001 | 09:02 AM
shamoo's Avatar
Will you make something up for me please?
Default Question on Drag III install...downpipe flange...where?
I'm installing my clutch and Drag kit as we speak. However, looking at the downpipe that is supplied, it doesn't look like it will bolt on directly to the cat. There is no flange of any type. Does it have to be fabricated?
Thanks. Hopefully this will be done very soon.
Old Oct 30, 2001 | 09:05 AM
jbsadler's Avatar
New User
Default Re: Question on Drag III install...downpipe flange...where? (shamoo)
The best thing to do is probably have a flex pipe installed and a free-flow cat....a good muffler shop should have the flanges in stock to weld on....HTH
Old Oct 30, 2001 | 09:16 AM
chri5's Avatar
Default Re: Question on Drag III install...downpipe flange...where? (jbsadler)
yes you will have to have a flange welded. As was mentioned by jbsadler it would be best to also gte a piece of flex pipe installed at this point betwen the DP and the cat. The reason for this is to keep the stress on the manifold down. Giving the flexing force of the motor a safe place to maifest itself, and not crack your exhaust manifold.
Speed94
Apr 14, 2008 01:56 PM
b00stedsi
Jul 10, 2002 04:24 PM
a z n t a k
May 7, 2002 11:47 PM
vtecsiqt
Feb 27, 2002 08:15 PM
