Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Source for GOOD radiator screen?
Old Apr 19, 2004 | 02:39 PM
Knestis's Avatar
Default Source for GOOD radiator screen?
I had a catalogue this fall that showed real stainless grill opening screen but can't find it now. Nertz. Anyone have a source?
K
Old Apr 19, 2004 | 03:04 PM
XrcR6's Avatar
Default Re: Source for GOOD radiator screen? (Knestis)
Kirk,
Try here: http://www.pegasusautoracing.com/. Actually here's the link to the PDF of page 44 of their catalog: http://www.pegasusautoracing.com/pdfs/044.pdf
304 stainless wire cloth, searching on "wire cloth" will bring it up in the Order On-Line section too. Def. beats the stuff from the hardware stores that tarnishes after a while.
Old Apr 19, 2004 | 03:10 PM
Knestis's Avatar
Default Re: Source for GOOD radiator screen? (XrcR6)
Ah! That is it - thanks!
K
Old Apr 19, 2004 | 06:08 PM
Catch 22's Avatar
Ace Hardware.
Chicken Wire. I painted mine black.
Still have most of the roll. Think I paid $3.99 for it.
Old Apr 19, 2004 | 07:41 PM
TeamSlowdotOrg's Avatar
Default Re: Source for GOOD radiator screen? (Catch 22)
That's what I would do. Stainless is too bling for me.
Old Apr 19, 2004 | 07:47 PM
Default Re: Source for GOOD radiator screen? (TeamSlowdotOrg)
Also, found this on McMaster-Carr:
http://www.mcmaster.com/param/...=6235
Old Apr 20, 2004 | 03:10 AM
Geezer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Catch 22 &raquo;</TD></TR><TR><TD CLASS="quote">Ace Hardware.
Chicken Wire. I painted mine black.</TD></TR></TABLE>
Old Apr 20, 2004 | 04:28 AM
Todd Reid's Avatar
Default Re: Source for GOOD radiator screen? (Geezer)
catch22 is spot on. i used the heavier chickenwire as a first defense, and as a latice onto which i could attach a finer mesh household windowscreen mesh.
i am protecting a very expensive Howe combination radiator/oil cooler.
it looks perfect after a year of racing. without it, the lower section of fins would be totally battered and smashed in, plus jammed with rubber marbles.
total cost, about $10. that includes chicken wire, window mesh, and a ton of small zip ties.
Old Apr 20, 2004 | 04:44 AM
MattD@Stoptech's Avatar
Default Re: Source for GOOD radiator screen? (Todd Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd Reid &raquo;</TD></TR><TR><TD CLASS="quote">catch22 is spot on. i used the heavier chickenwire as a first defense, and as a latice onto which i could attach a finer mesh household windowscreen mesh.
total cost, about $10. that includes chicken wire, window mesh, and a ton of small zip ties.</TD></TR></TABLE>
Keep in mind that most window meshes have very little free area (less than 50% open area is not uncommon) so you're really cutting down on the airflow through the radiator.
As usual, everything is a compromise
Old Apr 20, 2004 | 06:28 AM
Todd Reid's Avatar
Default Re: Source for GOOD radiator screen? (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">
As usual, everything is a compromise </TD></TR></TABLE>
hi matt!
yup; as an engineer, this is the first thing i considered..... but, the rad i ordered from Howe was oversized; way oversized. its for a circle track racecar; rated conservatively for a 450 hp racecar running long races (200+ miles). so i think i could cut it down to almost no airflow and it would be ok. as it was, the first time out, with the mesh screen in place, i had to replace the old orifice plate i had in place of the thermostat (which is what i ran with the delsol vtec rad) with a stock thermostat. the engine wouldn't warm up at all with the orifice plate in. the rad is way overkill; i never have to worry about overheating again!
in fact, i don't run a fan (the rad is so thick that there is not clearance for one). she will stay under 200 degrees when sitting and idling, just from convection, on an average day. i have let it idle for 30+ minutes like this, observing it. gridding up and waiting for a race is no problem; in fact, i have to startup early in order to get some heat into the motor so it is ready when the green drops!
todd
Windizzle
Oct 20, 2011 12:03 PM
sabideefoo
12
Oct 12, 2010 05:51 PM
wesley_925
Jun 30, 2008 09:37 PM
ctr83
Feb 24, 2008 11:21 AM
dragneon
Oct 22, 2007 01:46 PM
