To anyone with the Auto Meter a/f guage...
Old Oct 30, 2001 | 08:35 AM
FBP Si 2000's Avatar
Default To anyone with the Auto Meter a/f guage...
During idle and while I am driving...the a/f guage reads on the rich side. WOT, it stays on the rich side also, seems like it doesn't move...so what I was wondering was, is that normal? Maybe I wired it wrong? Let me know, thanks in advance.
Old Oct 30, 2001 | 08:36 AM
DragII's Avatar
25 Year Member
Default Re: To anyone with the Auto Meter a/f guage... (FBP Si 2000)
no, you have it wired wrong, if it is installed correctly, it will bouce back and forth non stop.
Old Oct 30, 2001 | 09:03 AM
Default Re: To anyone with the Auto Meter a/f guage... (DragIIcivic)
I followed these directions... http://www.hondaracing.ca/installs/airfuel/index.htm
I'm pretty sure I spliced into the thick white wire since I doubled check before I did any splicing. Do you think I have a bad ground? Thanks
Old Oct 30, 2001 | 09:14 AM
CivicSiRacer's Avatar
When you car is warming up it should be rich, and at WOT it should be rich. But once your car is warmed up and happy it should bounce back and forth if you stay at a constant speed.
Old Oct 30, 2001 | 11:06 AM
HENRY's Avatar
New User
You definitely have the gauge wired incorrectly. Like everyone else says, it's suppose to bounce back and forth and should only be in the green for WOT and warming up. It sounds like you tapped the wrong wire going into you ECU. If I recall correctly, there are actually two solid white wires that go to the ECU. At least mine did (97 Civic EX). The gauge reads voltage coming from your O2 sensor and interprets that to a rich/lean measurement and apparently, it's reading an incorrect voltage. Double check and make sure you have the correct white wire.
Old Oct 30, 2001 | 03:04 PM
JDMb18civic's Avatar
u mite have a bad o2 sensor...
did u tap it on the white wire....
Old Oct 30, 2001 | 04:47 PM
Default Re: To anyone with the Auto Meter a/f guage... (JDMb18civic)
I tapped it to the correct wire...it's just that the t-tap I used didn't make a good connection. It is fixed now, thanks for all your help.
95integraLS003
Sep 10, 2005 04:22 PM
DarkBB4
Sep 4, 2004 03:27 PM
SilverEP3
Jul 5, 2002 06:58 AM
Qwikrex
May 5, 2002 01:38 AM
