air fuel ratio question... need answer asap
Old Apr 19, 2004 | 12:51 PM
mustbenu's Avatar
Default air fuel ratio question... need answer asap
just used my innovate wide band on my car.
i have a b16a
edelbrock intake manifold, short ram intake, 2.5 straight pipe(no cat)
aem fuel rail, fuel pressure reg.
i read 14.4 on the wide band at idle
and then i took my vacuum hose off for WOT(wide open throttle)
and i read 13.7 at WOT
i dont have a EMS so i cant tune in increments but this is a drag car so what a/f numbers shall i try to reach to maximize power????
Old Apr 19, 2004 | 12:56 PM
-KangaRod-'s Avatar
I'd try to get it a little richer, maybe in the 12.5 range, but every car is a little different.
Old Apr 19, 2004 | 01:00 PM
mustbenu's Avatar
arent you supposed to run leaner to maximize power without detonation
you think if i run richer it will maximize the power?
Old Apr 19, 2004 | 01:28 PM
96-EJ6 B18C's Avatar
Default Re: (mustbenu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustbenu &raquo;</TD></TR><TR><TD CLASS="quote">arent you supposed to run leaner to maximize power without detonation
you think if i run richer it will maximize the power?</TD></TR></TABLE>
Yeah, I can't remember the exact # for max power but I do remember that it was 12.X...My Si motor runs about 11.8-12.2 AFR WOT at redline.
Old Apr 19, 2004 | 03:26 PM
B2FiNiTY's Avatar
Default Re: (96-EJ6 B18C)
There is no exact number for max power. Every car runs different and should be tuned accordingly.
Old Apr 19, 2004 | 03:31 PM
mustbenu's Avatar
Default Re: (B2FiNiTY)
well i dont have a dyno
but do u think on average that 12.5 a/f will post better numbers than 13.7 at WOT for my setup.
Old Apr 19, 2004 | 03:33 PM
roadawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustbenu &raquo;</TD></TR><TR><TD CLASS="quote">well i dont have a dyno
but do u think on average that 12.5 a/f will post better numbers than 13.7 at WOT for my setup.</TD></TR></TABLE>
Around 12.5 at WOT is a good starting point..
Old Apr 19, 2004 | 03:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">There is no exact number for max power. Every car runs different and should be tuned accordingly. </TD></TR></TABLE>
Good answer! for me. Most cars seem to do best in the 12.X range though.
rdssk8rcs1
Apr 22, 2008 07:22 PM
SVOboy
24
Jul 22, 2005 12:02 PM
O16581724 5 2 5
May 17, 2005 10:21 AM
SpoonFedHatch
Feb 24, 2004 06:20 PM
FuzzyGreen
Feb 26, 2002 12:14 PM
