Maint Reqd Sign??
check your owners manual to see if you're up for some maintenance. depending on you're mileage you might be due for something. if you're all caught up to date you can just turn off the light.
its just a light that means nothing... acura made it so taht it comes on ever so miles... hoping u bring it in and spend money... u can get it off ur self... all u do is cut the ignition on too 2 clicks.... then feel under the rigth side if the driveer side dash and feel for a box with a button on it... once u do find it holf the botton down for a few seconds... then u will see the maintence light go off... this light means nada trust me... ionly light u should worry about is a check enigne light
Guest
Posts: n/a
there is a module that controls that light. It comes on every 7500 miles or so...it's a dealer gimmick to have you rely on them for service...ghey. If you're sure everything is up to spec, look under your dash on the driver side below the steering wheel for a square blue button..turn your car on and hold the button. It should reset it and make it go away.
