MASER CYLENDER
Old Apr 19, 2004 | 09:12 AM
b18cEF9's Avatar
Default MASER CYLENDER
i did a rear disk swap on my dx hatch with some stainless steel lines also, should i upgrade the master cylender witha DA?
Old Apr 19, 2004 | 09:23 AM
4drEF's Avatar
Keyboard Humorist
Default Re: MASER CYLENDER (b18cEF9)
A DA 15/16" MC??? That will require you to cut one of your hard brake line fittings and then reflare the line with the properly sized Integra fitting. You will also have to swap out your stock brake booster for the Integra one becasue the Integra MC won't work on your stock booster. Booster isn't much fun to replace.
The MC from the 90/91 Civic Sedan EX is 15/16" and will bolt directly onto your stock booster. No line mods and no booster replacement.
Old Apr 19, 2004 | 09:36 AM
cursED's Avatar
Default Re: MASER CYLENDER (4drEF)
You can switch over the both the master cylinder and booster from the 90-91 Civic EX 4dr. without a problem.
em1pusha99
11
Jul 21, 2009 06:27 PM
StreetRacin101
30
Apr 9, 2009 04:38 PM
LSej1
18
May 6, 2008 03:39 AM
B HATCH
11
Apr 15, 2004 05:07 PM
Bnjmn
10
Dec 8, 2002 03:08 PM
