p13 ecu auto vs. manual??
Old Apr 19, 2004 | 09:08 AM
SlowAssAccord's Avatar
Default p13 ecu auto vs. manual??
hey i have a question about ecu's.. i have a h22a and jdm p13 OBD1 that was put in an auto prelude. now that i am swaping the h22a into a manual 4th gen accord do i need an new p13 ecu made for the manual tranny? or is it the same ecu?? also is there a better ecu to use on the h22a? i have a friend that is using a gsr ecu?
Old Apr 19, 2004 | 09:13 AM
SearchBeforeUPost!'s Avatar
Default Re: p13 ecu auto vs. manual?? (pos92accord)
you will be fine with the p-13 J-AT
Old Apr 19, 2004 | 01:21 PM
Default Re: p13 ecu auto vs. manual?? (SearchBeforeUPost!)
no mods need to make it work with the F22 5speed tranny??
Old Apr 19, 2004 | 04:40 PM
v4lu3s's Avatar
RTFM
the engine computer is only for the engine, the tranny computer comtrols the auto tranny...you should be fine.
Old Apr 20, 2004 | 08:51 AM
Default Re: (v4lu3s)
cool thanks!
Old Apr 22, 2004 | 09:24 AM
Siegfried's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">the engine computer is only for the engine, the tranny computer comtrols the auto tranny...you should be fine.</TD></TR></TABLE>
Present like this it sounds right
but why did they make AT and MT ECU then ?
I mean what' s the difference between the 2 ECU type, I know that there are additional components on AT ECU.
Also, when you put another ECU for exemple let say P28 instead of P13, do you still have the same Error codes ? and does it work fine on your engine even it' s not the original ECU: not throwing CEL ?
Old Apr 22, 2004 | 05:48 PM
Default Re: (Siegfried)
I have used both the auto and manual P13 on my h22, when it was both auto and manual! They both work.
I don't really understand your second question.
Old Apr 23, 2004 | 09:03 AM
Siegfried's Avatar
Default Re: (SearchBeforeUPost!)
Don' t get angry
I didn' t say it doesn' t work,
I' ve read in another topic it should be be fine.
but I just wanted to know what' s the difference between the 2 ECUs as they are additional components inside AT ECU, and I read a lot of topics but never read one that says what' s the difference between them.
For the 2nd quest°, I wanted to know if I put another ECU that was not in my car but is compatible, will my car behave the same and not throw me a CEL,
and for the CEL, if I got one later, will the Error codes be the same.
I know it' s not related really to the main topic but it' s something I still don' t get as I' ve never plug another ECU on my car.
kinvid22
Mar 24, 2018 07:30 AM
KleenL
Nov 24, 2007 01:29 PM
djnikko
Mar 17, 2005 08:39 AM
OzWolfbane
Jan 11, 2005 07:15 PM
Acclude
Sep 11, 2002 08:39 PM
