i misshifted again today...
Old Apr 19, 2004 | 07:47 AM
ranivus's Avatar
Default i misshifted again today...
...trying to go around a semi and i misshifted to 2nd from 3rd instead of going to 4th.
Thats twice in 3 months, i was just curious on what serious problems misshifting causes, even if i drop the clutch for like 1/2 a second.
Old Apr 19, 2004 | 08:53 AM
allmotor-s's Avatar
Default Re: i misshifted again today... (ranivus)
It depends, did you red line in 3rd? If you did then that could be a bad thing. Mainly what you'll do is bend your valves and mess up your valve springs. Does your car run ike it did when you first had it?
Old Apr 19, 2004 | 09:23 AM
ranivus's Avatar
Default Re: i misshifted again today... (allmotor-s)
well it runs as normal as it has been even a lil better since i cleaned my filter yesterday, and put some fuel injector cleaner in my tank.
Old Apr 19, 2004 | 09:45 AM
GreenBean's Avatar
Get a Short Shift adapter, Like Neuspeed or DC-Sports (like I have) and then get a Momo or a Sparco shift ****(one with set screws)...The **** will have a 2-3.0" depth to it and will go completely down over your shift rod. You will be amazed at the difference in throw length and wish it were the first mod you had done....
Old Apr 19, 2004 | 10:19 AM
oldB18EF's Avatar
Default Re: i misshifted again today... (GreenBean)
point your hand backwards and away from you when you shift into 4th, you are WAY less likely to mishift, trust me I know the 3rd to 2nd is what killed my Type S when I had it (2 valves and 2 cylinders= $8k fix)
Old Apr 19, 2004 | 10:32 AM
ranivus's Avatar
Default Re: i misshifted again today... (notec oldhatch)
$8000??? wow you could've bought a k20 engine +shipping +turbo +installation!!
im assuming you're exaggerating a lil to get to the point
so how do i go about checking it out? i just want to get it checked out before i actually drop a turbo in. cause if there is problems ill just go ahead and get a motor swap
Old Apr 19, 2004 | 11:30 AM
oldB18EF's Avatar
actually no im not exaggerating at all, if the dealership would not have covered it a K20A2 bottom end and head plus labor to put it in was a little over 8000....not very cheap
needless to say i never trusted myself on the 6 speed again sold it and got a base
Old Apr 19, 2004 | 11:49 AM
fireant's Avatar
notec is right, I had the same problems, and it seems to be fixed since I changed my habits while shifting. The high shifter on the Si makes it especially easy to get into a habit of pulling towards yourself when you shift because you are naturally grabbing it from the side instead of from above.
Before, I was always grabbing the shifter with my palm facing me and pulling or pushing... the problem with doing that is on the up shift, if you make an error, its most likely going to be a downshift instead of an upshift.
So now, when I go from 2nd to third, I put the outer edge of my palm down on the top ****...the part below my ring finger...the push up and slightly away... the only error I can make is going to 5th instead of 3rd.
When Im going from 3rd to 4th, I make a hook-like grab, with my palm facing outward, thumb facing down. Again, you are pushing slightly out instead of pulling inward...and reverse is too far off to engage if you miss.
This seems to do the trick for me. it just takes some practice.
Old Apr 19, 2004 | 01:58 PM
TheNewPunk's Avatar
Default Re: i misshifted again today... (hatch2k)
Maybe you should just get a car with an auto tranny next time. The EP tranny is not easy to misshift on. Maybe if you had a type-s.
Old Apr 19, 2004 | 05:38 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notec oldhatch &raquo;</TD></TR><TR><TD CLASS="quote">actually no im not exaggerating at all, if the dealership would not have covered it a K20A2 bottom end and head plus labor to put it in was a little over 8000....not very cheap </TD></TR></TABLE>
Dealerships are the equivalent to medieval Thieves Guilds. $8k my puckered *******.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">needless to say i never trusted myself on the 6 speed again sold it and got a base</TD></TR></TABLE>
I hope you don't apply that cowardly logic to everything in your life.
"Well, I dribbled on the seat: better chop off my **** and install a vagina so there's no chance of that ever happening again."
Might as well have if you copped out on manual transmissions .
Old Apr 19, 2004 | 07:17 PM
oldB18EF's Avatar
Default Re: i misshifted again today... (Archidictus)
thanks for the opinions but i could give two *****
just giving dude some helpful information hes asking for not your grief
Old Apr 19, 2004 | 07:34 PM
civic_hatchback's Avatar
That sux, the type S has a really close gear box, i wonder if you saw the pic of a guy who redlined 3rd and shifted to 2nd, parts blown all over, it was nasty. The type S has taken many peoples money from their gear box. Wonder if its cheap to get a diff one? Or if they make them? I have no idea?
Old Apr 20, 2004 | 07:00 AM
Mediocre Generica's Avatar
Default Re: i misshifted again today... (civic_hatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_hatchback &raquo;</TD></TR><TR><TD CLASS="quote">That sux, the type S has a really close gear box, i wonder if you saw the pic of a guy who redlined 3rd and shifted to 2nd, parts blown all over, it was nasty. The type S has taken many peoples money from their gear box. Wonder if its cheap to get a diff one? Or if they make them? I have no idea?</TD></TR></TABLE>
A course in how to drive would be cheaper and more effective.
Old Apr 20, 2004 | 09:49 AM
Default Re: i misshifted again today... (Mediocre Generica)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mediocre Generica &raquo;</TD></TR><TR><TD CLASS="quote">
A course in how to drive would be cheaper and more effective.</TD></TR></TABLE>
Yeah it would be, or you can just pull it a tad to the right when shifting. You wont go into reverse. I have driven a type S and the gear box is closer than most cars. Most people pull it a little right when shifting to 4th and a little left to shift to 2nd. I dont think that you can go to 4th from 1st unless you pull it way over to the right. Right?
Old Apr 20, 2004 | 10:02 AM
fireant's Avatar
Different grips will help. There's a whole web page with pictures somewhere about the subject, I'll try to find the link.
Old Apr 20, 2004 | 11:40 AM
fireant's Avatar
Here's the shifting techniques link: http://www.shortshifter.com/techniques2.htm
Old Apr 20, 2004 | 01:12 PM
Good site for someone who has never drivin a stick. Thats cool though, nice link, hopefully itll prevent the type S owners from ruining their cars.
Old Apr 20, 2004 | 02:04 PM
Tom5's Avatar
Do you guys think a SS would help this misshifting curse? I would think only because of the notchyness. But then I think with an even smaller gear box it could be worse. I was thinking about investing in one. Can't say I havent misshifted myself but I was fortunate.
Tom
Old Apr 20, 2004 | 05:34 PM
Default Re: i misshifted again today... (PIMPASSBEOTCH)
You can know how to drive and still misshift in a rsx. I watch this video from japan and this guy misshifted, but luckily he caught it in time, and got the clutch back in. Asians own us in driving so i dont think that its the people. Its partly the car
Old Apr 20, 2004 | 05:47 PM
fireant's Avatar
PIMPASSBEOTCH,
Read the April issue of Super Street with the Si Challenge. Both Roger Foo and Shawn Hiller had misshift issues in the Skunk2 civic that basically toasted thier chances in that contest. I would say both of them know how to drive better than most or all of us ever will.
The fact is: **** happens.
There's nothing to be gained in calling people DUMB ***. Even if it makes you feel better about yourself, it doesn't help anyone here.
Modified by hatch2k at 9:07 PM 4/20/2004
Old Apr 20, 2004 | 06:09 PM
[QUOTE=hatch2k]PIMPASSBEOTCH,
Well said That skunk2 civic is one sweet ride
Old Apr 21, 2004 | 08:09 AM
erottik-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch2k &raquo;</TD></TR><TR><TD CLASS="quote">
This seems to do the trick for me. it just takes some practice.</TD></TR></TABLE>
works too for the ITR just so we all know...
Old Apr 21, 2004 | 11:09 PM
Silver RSXs's Avatar
Default Re: i misshifted again today... (erottik-R)
if you've misshifted 2x in 1mnth...stop driving so hard before you blow up your engine. you may or may not have already done some pretty good damage. only time will tell
Old Apr 22, 2004 | 09:40 AM
Hella Flush Kevin's Avatar
Ignore me . . .
Whats so hard about shifting?
from 2nd to 3rd pop it in neutral, then clutch and push up.
3rd to 4th, pop it in neutral, clutch then push down.
3rd and 4th are already lined up. Practice more then you can slam the gears in.
Old Apr 22, 2004 | 11:59 AM
LBSolagger's Avatar
Just pay attention to what your doin. Half of all misshifts you cant control, like someone above said, **** happens, even to the best of us. The other half though is carelessness. i did it twice in the first month i got the car. That was 6 months ago and havnt had any since. Obvioulsy i have more practice now, but i also concentrate most on shifting when im drivin hard.
