burning alot of gas???
when my car is turned on, standing next to it, I can smell gas burning, I also got some friends who noticed it too plus my car eats alot of gas...what are my problem or is normal because of modification.
my mods.
skunk2 chip/p28
skunk2 cams
skunk2 cam gear
dc header/exhuast
66 mm holley throttle body
vortech fuel pressure
my mods.
skunk2 chip/p28
skunk2 cams
skunk2 cam gear
dc header/exhuast
I bet that Skunk2 chip in the ECU has something to do with it. It's fuel maps are probably designed to run ridiculously rich.
Are you throwing any kind of CEL?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg »</TD></TR><TR><TD CLASS="quote">I bet that Skunk2 chip in the ECU has something to do with it. It's fuel maps are probably designed to run ridiculously rich.
Are you throwing any kind of CEL? </TD></TR></TABLE>
yeah... it could be the chip.
if u have a chip that would do it - also check if all your sensors are hook up like MAF and Temp into the intake.. make sure ur not leakin .. leakin = fire
With a chip, throttle bodie and pressure regulater of course you will burn more gas. Now that you have more air and fuel dumping in and more exhaust dumping out, you need more spark to set the whole thing off. go get bigger wires, better plugs and an external coil and see what happens.
okay heres what I found out. did a close up examaning the wires and everything, it was fine but check spark plug and realized that it turned really dark at the bottom tip however these are cheap bosch spark plug that I put in new about two weeks ago, did it turn dark because it was cheap or something with the motor???also what kind of spark plug and wires should I get, my wires are shitty too??
