Hardwiring radar detector behind dash
Old Apr 18, 2004 | 11:08 PM
dk127's Avatar
Default Hardwiring radar detector behind dash
Ok, I want to hardwire my Valentine One and have the wire go behind the dash... Right now its in front and I don't like it. Does anyone have it coming up by the window behind the dash? I saw this done on a CL once and pondered how they did it..
Old Apr 19, 2004 | 01:00 AM
epy's Avatar
epy
Default Re: Hardwiring radar detector behind dash (dk127)
I think you should read this thread
https://honda-tech.com/zerothread?id=467854
Old Apr 19, 2004 | 11:11 AM
dk127's Avatar
Default Re: Hardwiring radar detector behind dash (epy)
what the HELL?!? I thought I searched for every possible combination of hardwire and valentine one, 1, and I couldn't get ANYTHING..
i guess the only thing I didn't search for was just plain Valentine 1.
although i swear i thought i did..
Old Apr 19, 2004 | 11:21 AM
dk127's Avatar
Yea, and that still didn't answer my question of hardwiring it behind the dash. I want the radar detector on the window, not a concealed unit behind the clock, I just want to run the power behind the dash.
Old Apr 19, 2004 | 11:34 AM
sackdz's Avatar
Default Re: (dk127)
so wire it into the clock. thats what i did. the clock has 4 terminals, power (acc), ground, and backup, and illum. wire it to the acc. and ground
I believe its the 2 outside pins of the V1's RJ-11 connector.
Old Apr 19, 2004 | 11:36 AM
cheezthis's Avatar
Default Re: (sackdz)
You can also run a wire from the fusebox, and then hide the wire bwt. the dash and windshield. It's not rocket science, just use something to "tuck" it in there.
Old Apr 19, 2004 | 11:54 AM
dk127's Avatar
Default Re: (cheezthis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheezthis &raquo;</TD></TR><TR><TD CLASS="quote">You can also run a wire from the fusebox, and then hide the wire bwt. the dash and windshield. It's not rocket science, just use something to "tuck" it in there.</TD></TR></TABLE>
where does the wire come up from? i have no problem hardwiring it, its already hard wired, i just need a place to pop up between the dash and windshield to run the power
Old Apr 19, 2004 | 12:21 PM
sackdz's Avatar
Default Re: (dk127)
clock. take it out. wires.
Old Apr 19, 2004 | 07:50 PM
dk127's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">clock. take it out. wires.</TD></TR></TABLE>
ok. its already hardwired. i don't need to hard wire it. i don't want to put it where the clock is. i like to know what time it is. what i want to do is leave it on the window, but have the power coming up behind the dash. i don't want it coming from the clock, the clock probably won't end up fitting right.
what i need to know is where do i pull the power up from behind the dash?
and my god PLEASE DON'T SAY CLOCK AGAIN
Old Apr 19, 2004 | 08:03 PM
Kicker773's Avatar
Default Re: (dk127)
i'd like to see you do it.. i never had a radar detector didn't think i'd need it.. but for the future.. it be anice DIY proj with directions
Old Apr 19, 2004 | 10:04 PM
cheezthis's Avatar
Default Re: (dk127)
Ugh...
You don't have to pull up anything, trust me. I work in a stereo/alarm install bay.
Old Apr 19, 2004 | 10:12 PM
dk127's Avatar
but where does it come up from? you said tuck it in between the dash and window, are you saying i should run power up the side around the dash from the bottom to the top then from the side to the middle? thats all i need, how to get from my hardwire source (tapped into cig lighter) to the radar detector...
i don't NEED it, but i don't like the cord there. its hardwired pretty far low, and the rubber on the cord is starting the break from the stress. i'm pretty busy, so i don't have time to play with the car. i wish i did..
Old Apr 19, 2004 | 10:39 PM
sackdz's Avatar
Default Re: (dk127)
You will have to remove the dash partially to get a wire around the top of the dash, since for some reason you dont want it coming thru next to the clock, which you do not need to remove the dash for, which is why I said clock. Which is where my wire went thru, on a retractable phone cord that coiled up when it wasnt being used.
I didnt say put the radar detector in the clock housing. I said run the wire from there.
You may have to notch the dash behind the clock facia, but you wouldnt be able to see it with the clock in place. An alternative would be to drill a small hole in the upper middle vent duct and run it thru the vent. Any other way is going to leave exposed wire running along the dash. You could also go from the dome light, but the headliner is a bitch to remove.
Old Apr 19, 2004 | 11:17 PM
cheezthis's Avatar
Default Re: (dk127)
You run that wire from wherever you tapped into (I used fusebox)...along the bottom of the dash, up the side of the dash by the door, and along the crack bwt. the dash and windshield. If you tuck it in tight, it will not ever move out unless you pull it out. I've had zero problems w/mine, and it's been a few years since I installed it. And...my car sees various events throughout the year, so it gets tossed around a bit.
fit2bee
Honda Fit
May 19, 2018 11:56 AM
redboost10
Aug 10, 2006 01:48 PM
