Will my brakes be ok?
Old Oct 30, 2001 | 05:38 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Will my brakes be ok?
I am doing the Summit Pt 2-day driving school this coming weekend. My stock brakes/pads/fluid have seen 2 mildly abusive track days already on the Summit Pt. short course, this will be my first time doing the full. Do I need new pads/fluid ASAP or should the stockers be ok for at least this weekend? Thanks guys.
Old Oct 30, 2001 | 05:41 AM
Willard's Avatar
Default Re: Will my brakes be ok? (Ross1013)
I would flush the fluid for sure.
The pads may hold up but a better set of pads would make the weekend a little bit easier. One les thing to worry about.
It should be 65-70 (with a chance of rain)... so I am not sure if the pads would be required.
Will
Old Oct 30, 2001 | 05:57 AM
Ross's Avatar
25 Year Member
Community Builder
Default Re: Will my brakes be ok? (George Knighton)
The thing is that mail sucks at my school. If I ordered pads from, let's say, Carbotech, they wouldn't get to me until after the event. Jon Felton is RacerJon right?
Old Oct 30, 2001 | 07:20 AM
Honda318dx's Avatar
Jon is going to be away for a while, so it might be difficult to get stuff threw him, if you call carbotech, if they have them on the shelf, they will get to you in time.. Carbotech Panther Plus pads.. 125$ or so..
By the way, the big track is a lot easier on brakes then the small one..
Old Oct 30, 2001 | 07:22 AM
Warren's Avatar
Wrong-Way Wang
Default Re: Will my brakes be ok? (Honda318dx)
That's cuz you keep using that damn pedal in the middle. You'll be alot faster if you don't use it so much
Warren
[Modified by Warren, 8:22 AM 10/30/2001]
Old Oct 30, 2001 | 07:25 AM
Honda318dx's Avatar
Default Re: Will my brakes be ok? (Warren)
Im working on that.. Only have 4 braking zones on the big track now =~).. the ones for 3 and 10 are just droping the car 20mph
If I didn't use that middle pedal, I would run into your ***
Old Oct 30, 2001 | 08:20 AM
Ross's Avatar
25 Year Member
Community Builder
Right after I buy my Carbotechs I am going to start a fund - "Sequential Shifter for Warren ****".
Old Oct 30, 2001 | 08:25 AM
fangtl's Avatar
So this is a rain or shine event right?
Old Oct 30, 2001 | 08:26 AM
Yellow Dragon's Avatar
Upgrade the fluid for sure. If you're short on $$ get some heavy duty Ford fluid. It's a lot less then the other stuff.
I went with HP Plus pads just for my fronts and I'm impressed. I wouldn't say they would be absolutely necessary, but it would be a good option.
Good luck.
Old Oct 30, 2001 | 08:28 AM
Ross's Avatar
25 Year Member
Community Builder
Default Re: Will my brakes be ok? (Yellow Dragon)
Would any shop carry this stuff? Im an absolute moron with a wrench so Id also need it done for me.
Old Oct 30, 2001 | 08:56 AM
Changing the brake pads is VERY simple. There's one bolt to remove on the front of the caliper and it lifts up to expose the pads. You can remove them like so, and put in the goods.
Flushing your fluid requires more patience...and it also helps to have a second set of hands.
Old Oct 30, 2001 | 09:02 AM
Honda318dx's Avatar
With just a wrench??
Old Oct 30, 2001 | 09:04 AM
Honda318dx's Avatar
Ross, Find me at summit point.. I'll show you how to put new pads on.. VERY simple.. although make sure to have your pad on before you come, so you can bed them in.. directions for bedding them in comes with the pads..
[Modified by Honda318dx, 1:05 PM 10/30/2001]
Old Oct 30, 2001 | 09:10 AM
Warren's Avatar
Wrong-Way Wang
Nah, he can just bed them in at the track. What do you think all the race car drivers do? Just go easy, cuz the brakes will be somewhat unpredictable during the bed in session, BUT do make sure that you get them nice and hot.
I need a 1st and 2nd gear blocker
Warren
Old Oct 30, 2001 | 09:12 AM
Honda318dx's Avatar
Warren
Remember Warren, we are talking about Ross here
Old Oct 30, 2001 | 09:13 AM
I would suggest changing the pads early...before you get on the track. Go for a few dry runs in the paddock area to break them in. That's what I did with mine.
Old Oct 30, 2001 | 09:14 AM
Honda318dx's Avatar
You would **** EVERYONE off at summit point doing this.. That, and its so crowded, its dangerious
Old Oct 30, 2001 | 09:21 AM
I didn't realize how many people would be there. I've never been to Summit Point. I've only been to Heartland Park (Topeka, KS) and there's some places that you can do a little breaking in. Not 100mph-0 blasts or anything.
Actually, I left the track briefly and did some braking in (pun intended) on the access roads to the track.
Old Oct 30, 2001 | 09:44 AM
Type-R 940's Avatar
New User
Absolutely change your fluid, and pads aren't a bad idea either. I did a lapping day at Gingerman raceway and I boiled my brake fluid very quickly. I also basically destroyed my pads, as they couldn't handle the heat that built up in the rotors (or at least this is my explanation as to why I only have a few mm of pad left in the front). When I got off the track my front rotors were glowing red hot. You can build some pretty serious heat up if you stay out on the track for a while, so make sure you have a pad that can handle it.
TypeR864
Apr 26, 2005 09:39 AM
NewR
Apr 9, 2003 09:19 PM
Rain_man
Jun 24, 2002 11:52 AM
ITR00-816
15
May 23, 2002 09:38 AM
onyx00
Jul 3, 2001 09:31 AM
