Clutch Opinion
Old Apr 18, 2004 | 10:26 PM
FlexW99's Avatar
Default Clutch Opinion
Hey Bros,
Need an opinion here. Im rebuilding a d16a6. Im planning on eagle rods and rollerwaves for pistons. Or maybe not. The issue as usual is money. But either way ...Im runnin boost..whether it be stock or on a nice solid bottem end. If I run stock, then ill run 6-8 lbs of boost. If I run the eagle rods and pistons, then ill run the boost higher. Im also going to use an aluminum flywheel. Now heres the question.
I had my sights on a CM stage 3 clutch. I was scammed and never got it. Honestly im out big money wise and product wise. Im looking into a more budgetable clutch...and this car is only used on the weekends...I drive an Accord as a daily driver...
Whattya guys think? ...Im looking into the exedy organic...could that hold 8lbs of boost? ....im also lookin at the ACT 6 puck...how about a Centerforce?...rather cheap but apparently they hold 90% over stock....voice your opinions...thanks...
also, if this helps, i dont see this car as a 'long haul' type of car...ill use and abuse it for a year or so then dump it and move on to the b series...
Old Apr 19, 2004 | 07:01 AM
FlexW99's Avatar
Default Re: Clutch Opinion (FlexW99)
bump for help
Old Apr 19, 2004 | 07:07 AM
tilt's Avatar
i have exedy racing organic running 8-9psi. so far it is holding up.
I would go for something like a cm stage3 if you are going to run more boost.
Old Apr 19, 2004 | 07:24 AM
Senpai_r's Avatar
Default Re: Clutch Opinion (tilt)
I've had good luck with my ACT XTSS. It requires a stronger calf though.
Old Apr 19, 2004 | 07:28 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
agreed with tilt on this one...
Old Apr 19, 2004 | 08:11 AM
FlexW99's Avatar
how is that setup treatin ya tilt? you runnin an A6 as well?> any hp/tq #'s? or 1/4 mile times?
Old Apr 19, 2004 | 09:08 AM
tilt's Avatar
it's a d15b2 with mpfi conversion... it pretty much performs like an a6.
havent taken it to track or dyno tuning(i know i should). but I've ran it against my friend's stock s2000, and the S was just a tad faster.
As for the clutch, I would only recommend it if you are on a budget. it is prob close to the bare minimum you should use. the racing clutch, organic disc is rated at 69% increase in clamping force -- so if you are making 150ft lb torque thats prob coming close to the limit. i'm sure the numbers they get are for ideal sitations, and i doubt every clutch will perform the exact same.
cerametallic is 133% increase... that might be better but i dont know about smoothness or how long it lasts.
Old Apr 19, 2004 | 09:32 AM
FlexW99's Avatar
thanks for the info.....any others fellaz?
Old Apr 19, 2004 | 08:59 PM
FlexW99's Avatar
bumpity
bmiller17
Sep 16, 2006 08:50 AM
crazy_eddy
Nov 15, 2005 06:50 PM
Mr. JDM-GSR
Jan 30, 2004 10:38 AM
1.8T_EG
Feb 8, 2003 11:47 AM
donnie B
Dec 1, 2002 08:49 PM
