Xbox in car what inverter
ok i have my xbox modded with 850 albums on it Xbox media centre its all hooked up and in the boot lcd screen in front
the thing is i had to get a inverter for the box to work from 12v to 230v ( aussie) there are two types modified square wave inverter and pure sine wave inverter
400 Watt square is = 150 ( Aus dollars )
300 watt Sine wave = 320 ( Aus dollars )
they guy at the store was pushing the pure sine wave saying it would be better and i would get longer life out of the xbox power supply well as a xbox isnt that much i thought save the money get a square wave inverter
it works i was using it for a week no probs now it doesnt seem to work but the xbox is ok inverter turn on but now power dud ?? or should i exchange for sine ?
my question is anyone have any experiance with this sort of stuff all new to me
I just got my inverter and xbox installed at a pro shop. I wanted it hooked to the battery is because I heard that was better. But they tapped into some wire or wired it to the fusebox somehow is that ok? Does that do just the same thing. Because at first I had interference but I moved some wires around and taped up some wire on the back of the HU and now its fine. Anyone know the answer to my question?
i have a jenson 160w power converter and i have a 20amp 32v pluged into there and its pluged into the cig lighter the power converter works but the xbox doesnt seem to be gettin enuff juice, i saw that it said like 100v-120v' 2.1 a so i think i need that much juice but do they make an amp 100 volts? this setup worked on my friends ps2 by the way
ShaneD16
Nov 12, 2005 03:17 PM
