IGNITION QUESTION?? H22 SWAP?
Old Apr 18, 2004 | 06:21 PM
ricekiller1's Avatar
Default IGNITION QUESTION?? H22 SWAP?
`i just finished my swap kinda? my jdm h22 is in my 1994 accord and is all wired up. as far as i know everything is ok with the wireing to the ecu but im not getting any spark?i was wondering if everyone just wires in the internal coil distributor that comes on the jdm h22 or if most people buy a usdm one and just plug it in? please help me with the wireing so i can get my car running.
Old Apr 22, 2004 | 04:24 AM
luderzzz's Avatar
Default Re: IGNITION QUESTION?? H22 SWAP? (ricekiller1)
i just did that smae swap and ran into the same problem thank god i had my h23 dist. laying around in the garage. i would try to find a cheap h23 dist. or try to put just the h23 dist. cap off and put that on.
Old Apr 24, 2004 | 05:51 PM
Default Re: IGNITION QUESTION?? H22 SWAP? (luderzzz)
thanks for the info but i figured it out!!all you have to do is slice two wires together that went to the old external coil. there are three wires. GREEN, YELLOW AND BLACK AND YELLOW. the green wire is worthless so just splice the other two together and your all set. mine fired right up!!!
CHECK OUT http://WWW.HONDAHOOKUP.COM
EMMISION SHUT DOWN FOR 90 DAYS IN CT!!! DAM DID I LUCK OUT
Krypto
Jul 14, 2014 01:01 PM
sscivicsi
Jun 15, 2008 10:05 AM
civictunr_ls
Jan 8, 2006 08:32 AM
jakeiscool
Mar 17, 2005 12:37 PM
volklude
Jun 26, 2004 11:42 PM
