recalibrate instrument panel 91 ls
hi. i f00ked up my stock instrument panel when installing indiglo gauges. more specifically, the temperture needle came off, the tachometer is lagged by 3500, and dont have tons of confidence in the gas gauge anymore. can i get these things recalibrated or am i hosed?
e-
e-
i think you can take it to acura and they'll do it for you.. but its not cheap.. not exactly sure how much it is.. but i member reading somewhere on the integra forums that someone jacked up there cluster and it costed them a good amount of change to get i calibrated again..
bump for answer..
bump for answer..
take the needle off and put it back on...on the other hand, the gas one wont be off, even if you jack the needle up.
awesome. the temp gauge needle came complety off and wont stay back on. is there a trick to this one? yer right about the gas gauge, that seems to work ok. thx.
