Need help w/ primary O2 wiring
A few weeks ago I installed a new header. Last weekend CEL # 41 started. I figured I must not have snapped the connector in securely. I take a look and noticed the wires actually came out of the female connector. I have a Helms, but I still can't figure out. Could someone please veritfy? Thanks
That's what I thought at first, but the actual wires came out of the connector itself. I reconnected them back into the connector as shown in the pic, but I cannot tell if it's correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danelot »</TD></TR><TR><TD CLASS="quote">A few weeks ago I installed a new header. Last weekend CEL # 41 started. I figured I must not have snapped the connector in securely. I take a look and noticed the wires actually came out of the female connector. I have a Helms, but I still can't figure out. Could someone please veritfy? Thanks
-the green wire should be @ the upper ground wire
-the white wire should be @ the green wire
-the black wire should be @ the white wire.
</TD></TR></TABLE>-the green wire should be @ the upper ground wire
I rewired it exactly how you stated and it worked fine...no cel. I also realized the the wiring is exactly the same as the secondary sensor. I could have use this as a reference. Thanks for your help.
z6hatchboy
Jul 2, 2008 07:34 PM
Civicse
10
Feb 11, 2006 11:13 AM
