Can i put SOHC VTEC head on my D15?
Old Apr 17, 2004 | 09:48 PM
VTECR021's Avatar
Default Can i put SOHC VTEC head on my D15?
I have seen some people do SOHC VTEC head swap on their non VTEC motors.
Can i put a y8 or z6 head on my D15b7? (its a Canadian DX) motor
Old Apr 17, 2004 | 09:51 PM
DAguyLS's Avatar
Default Re: Can i put SOHC VTEC head on my D15? (VTECR021)
yes you can, but I wouldn't really expect much from it
vtec in SOHC motors isn't very impressive due to the fact that it's only on the intake
Old Apr 17, 2004 | 10:00 PM
Tad's Avatar
Tad
yeah you can ppl do it al lthe time.
if you're putting it in that 95 dx hatch, itll be a pretty peppy setup,
a very noticeable change.
basically you'll gain around 20-30horses,
and bumped up compression.
I'm thinking about doing the same,
but throwing on a thinner headgasket for even higher compression, then a nicely aggressive cam(which will love the higher compression).
all that plus boltons in a light hatch will be a fun fun car!
might not be killin supras,
but hard to beat for the money
Old Apr 17, 2004 | 10:03 PM
DAguyLS's Avatar
^^^speaks the truth
Old Apr 17, 2004 | 10:05 PM
GSR-Civic's Avatar
Default Re: Can i put SOHC VTEC head on my D15? (slamdcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamdcivic &raquo;</TD></TR><TR><TD CLASS="quote">yes you can, but I wouldn't really expect much from it
vtec in SOHC motors isn't very impressive due to the fact that it's only on the intake</TD></TR></TABLE>
what the hell are you talking about? lol
Old Apr 17, 2004 | 10:10 PM
DAguyLS's Avatar
no, i was under the impression that he was just asking about the difference of vtec or non
my bad
Old Apr 18, 2004 | 09:18 AM
VTECR021's Avatar
ok, sounds good, i think im gonna try it, what all will i need in order to make it work properly? a vtec head, vtec solenoid, obd1 p28 ecu, make wires for vtec? of course, new head gasket, and other gaskets, and belts all the normal stuff. but what do i exactly need? or is there a site that has full explaination?
Old Apr 18, 2004 | 09:20 AM
zanthrax's Avatar
FAQ: D15 SOHC VTEC Mini-Me : Massive Write-Up
https://honda-tech.com/zerothread?id=554053
Old Apr 18, 2004 | 09:22 AM
Atheist's Avatar
Default Re: (zanthrax)
edit: you beat me to it
dohcMONSTER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zanthrax &raquo;</TD></TR><TR><TD CLASS="quote">FAQ: D15 SOHC VTEC Mini-Me : Massive Write-Up
https://honda-tech.com/zerothread?id=554053</TD></TR></TABLE>damn i was about to do that failure
Old Apr 18, 2004 | 09:54 AM
VTECR021's Avatar
thanks a million guys! that helped me! im going out to junkyard to look for stuff on tuesday!
Old Apr 18, 2004 | 10:16 AM
jerbear!'s Avatar
only exhaust you mean
Old Apr 18, 2004 | 11:42 AM
yonnage's Avatar
Did the Mini-Me swap last weekend Noticable difference!!!
Old Aug 22, 2004 | 07:40 PM
JdM_HoNda's Avatar
waddup guys i got a 94 civic dx coupe with a dx bottom end with a sohc intake manifold and del sol sohc vtec tranny tha motor has 175k on it and that **** pull lovely but i wanna know if i put sohc vtec head of it and with tha p28 ecu will tha car run more strong?
Old Aug 22, 2004 | 07:50 PM
jdmteg01's Avatar
Default Re: (VTECR021)
i have a d15z1 head off a vx d15 vtec with the soleniod and a po7 ill sell u??
Old Aug 22, 2004 | 07:58 PM
CivicVX94's Avatar
Umm...or not.
Don't say **** you don't know, it's the same on DOHC too
ONLY the intake has vtec, I think some body hasn't done their research
and to "jerbear" or whatever
vtec is on the intake side only on all sohc and dohc vtec motors. with some exceptions, all vtec-e motors, D15z1 and D16y7 (vx\hx) only have it on exhaust. they run 12 valves (8 intake and 4 exhaust) till around 3,000 rpm (when vtec engages) when they run on all 16 valves.
and on I-vtec and the 3-stage vtec D15B. THey combine the 2 together. So technically they have vtec on both.but only when real vtec kicks in and they run on the INTAKE vtec lobes will there be much of a power gain. they 12 valve (exhaust vtec) is for emissions bs
And i'm tired and don't feel like typing everything to explain this....
go to howstuffworks.com I think they have vtec on it....
this explains 3 stage vtec on the D15B
http://asia.vtec.net/article/d15b/
and I don't feel like searching for a link about i vtec but it's the same except the intake and exhaust have seperate cams...basically
and boom how vtec works
http://auto.howstuffworks.com/question229.htm
Modified by CivicVX94 at 5:27 AM 8/23/2004
Old Aug 22, 2004 | 08:24 PM
JdM_HoNda's Avatar
Default Re: (jdmteg01)
how much?
Old Aug 22, 2004 | 08:30 PM
CivicVX94's Avatar
Default Re: (JdM_HoNda)
trust me dude you wouldn't notice much of an improvement. the only little bit you would notice would be from the comp. jump due to small combustion chambers.but you could do the same by milling the head or a thinner head gasket.
Otherwise all you getting is a 12 valves motor until 3,000ish rpm and you gotta 16.
I would definately stick with whatever you got (at least it's 16 valves all the time), unless it's a CX. Or if you're really interested in Vtec-e and the roller rockers in the head.
OR go with a z6 or y8 or d15B head
Old Aug 22, 2004 | 09:24 PM
TommyTom83's Avatar
yes.
i_VTEC
Aug 22, 2007 01:09 PM
tryin_to_be_jdm
Oct 1, 2003 01:10 PM
egg
Sep 24, 2003 08:31 PM
juicedricer
Nov 6, 2002 08:52 PM
Civic89
12
Jul 6, 2002 10:29 AM
