Skunk2 IM or Stock GSR IM Port and Polished?
Old Oct 29, 2001 | 07:05 PM
comptechgsr's Avatar
Default Skunk2 IM or Stock GSR IM Port and Polished?
which one is better for me, and around how much is it for getting one's stock IM port and polished?
i have toda b's
and am installing jdm p73 pistons
AEM CAI for GSR
GSR T/B
Old Oct 30, 2001 | 05:36 AM
exquivical's Avatar
New User
Default Re: Skunk2 IM or Stock GSR IM Port and Polished? (comptechgsr)
Do you want to lose any low end torque? If not, Honed manifold, otherwise you will see a low end difference as much as a high end difference w/a Skunk2. I doubt I spawned all this talk about Intake Manifolds, but like I told a couple other people - I will be putting on my extrude honed intake manifold and b&M fuel pressure regulator sometime in the next couple weeks and post full results (hopefully I'll find time...it seems I have more time at work to do this than I do at home).
Old Oct 30, 2001 | 06:58 AM
FAST94GSR's Avatar
New User
Default Re: Skunk2 IM or Stock GSR IM Port and Polished? (exquivical)
I seriously doubt you are gonna lose torque. I don't know where everybody is deriving this from... Go Skunk. I have a graph of my gains , I didn' t lose torque anywhere. I made incredible gains in the midrange with that part. Its one of the best you can do for your car, especially since you have toda b's.
Old Oct 30, 2001 | 07:16 AM
6SPD_EK's Avatar
Default Re: Skunk2 IM or Stock GSR IM Port and Polished? (FAST94GSR)
with the high lift cams & higher compression I would go with the skunk2 mani - properly tuned you prob won't lose much low end torque. BTW - I am one that said you CAN lose valuable torque bolting on a Skunk2 mani - (in this case: to a relatively stock B18c1 engine w/stock cams & compression, without proper tuning) In this case I think the skunk2 could be very beneficial
Old Oct 30, 2001 | 08:26 AM
AK94GSR's Avatar
Default Re: Skunk2 IM or Stock GSR IM Port and Polished? (2000-4DRGSR)
I already have the skunk mani, but haven't got it on yet. I was actually thinking about getting it extrude honed, but not sure if I would need any thing else to go with it. I mean you would get alot more air into the engine so you would need more fuel right. I just ordered the B&M fuel pressure reg. w/ gauge. Do you think this would help if I was to do this???
Old Oct 30, 2001 | 10:30 AM
FAST94GSR's Avatar
New User
Default Re: Skunk2 IM or Stock GSR IM Port and Polished? (AK94GSR)
extrude honing would help, it would smooth out the roughness on the inside. I'm not sure the gains would justify the cost to do this. extrude honing is expensive. you might need a fpr, but you should probably get a vafc that would be a more valuable tuning tool for you.
andrewxxcarlson
Nov 24, 2011 08:51 AM
IloveAPC
Aug 20, 2004 06:00 PM
93civic_b18b1
Mar 6, 2002 08:37 AM
B18C-EJ1
Jan 20, 2002 04:24 PM
B18C-EJ1
Jan 20, 2002 01:16 PM
