2 questions 4th gen
Old Apr 17, 2004 | 08:24 PM
RUBZERK's Avatar
Default 2 questions 4th gen
well about 2 months ago i got a new set of rims & tires & i noticed that my gas mileage got real shitty
and prior to that i noticed that my car uses alot of oil.
what can cause it ???
Old Apr 17, 2004 | 08:28 PM
spankey167's Avatar
Default Re: 2 questions 4th gen (RUBZERK)
Seems like you got heavier rims... Typically heavier/bigger rims will cause your gas mileage go to ****...
The oil thing.. i have no idea... Bad piston rings? Bad seal?
Old Apr 17, 2004 | 08:37 PM
iam7head's Avatar
Default Re: 2 questions 4th gen (spankey167)
bigger rims shouldnt kick your gas mileage bad, some but not bad.
what rims that you got? rotational mass is a bit-h
the oil have nothing to do with the rims/wheels
Old Apr 17, 2004 | 08:47 PM
RUBZERK's Avatar
Default Re: 2 questions 4th gen (iam7head)
well i got a lighter rim than what i used to have, 17"
i went from 195-65-15 to 215-45-17
as for the oil, i change the oil every 3 months, (about every 1000 miles)
car dont smoke & dont idle above 800rpm
but i do have a bad exhaust leak
how do u know if the piston rings are going bad ??
Old Apr 17, 2004 | 09:56 PM
jwogen1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">but i do have a bad exhaust leak</TD></TR></TABLE>
how bad, or have you checked this more thouroughly
Old Apr 17, 2004 | 10:06 PM
RUBZERK's Avatar
Default Re: 2 questions 4th gen (jwogen1)
Its that bad that i can put my hand over the tailpipe & my hand is not forced away.
sounds like a whoopie cushion whan i give it gas
Old Apr 17, 2004 | 10:22 PM
jwogen1's Avatar
time for the magnaflow you have been considering!
Old Apr 17, 2004 | 10:31 PM
fw190bvi's Avatar
is your exhaust smoke a specific color???? are you leaking oil?
Old Apr 18, 2004 | 12:31 AM
D16Z6racing's Avatar
Default Re: 2 questions 4th gen (fw190bvi)
New exhaust. Recommend custom after I just got mine. Universal muffler, piping, and labor cost me $250 out the door.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">how do u know if the piston rings are going bad ??</TD></TR></TABLE>
Compression test, I think?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">well about 2 months ago i got a new set of rims & tires & i noticed that my gas mileage got real shitty, what can cause it ???</TD></TR></TABLE>
The PSI in your tires can also change your gas milegae. Be sure to have the proper inflation.
Old Apr 18, 2004 | 05:12 AM
RUBZERK's Avatar
Default Re: 2 questions 4th gen (D16Z6racing)
Well last night i just bought this magnaflow
& im getting 2.25 piping from cat back, no resonator.
Car does not leak oil or smoke.
As for tire air pressure, its good
Old Apr 18, 2004 | 05:38 AM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6racing &raquo;</TD></TR><TR><TD CLASS="quote">
And that new exhaust will help out your mpg too (back pressure) and a complete system. You should be happy with your choice, how much did it run you?
As for your mpg, check your spark plugs, air filter, plug wires, dizzy. You may also want to run some bg44K through your system too
Old Apr 18, 2004 | 06:53 AM
SearchBeforeUPost!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">well i got a lighter rim than what i used to have, 17"
do you mean the rim weighs less?
Even if it weighs less on a scale, it will weigh more on your car due to physics.
Also, the wider tire will decrease your gas mileage.
Old Apr 18, 2004 | 03:20 PM
RUBZERK's Avatar
Default Re: 2 questions 4th gen (SearchBeforeUPost!)
Muffler is running me $79.60 free shipping.
And $95 to install 2.25" pipe mand bent from cat back.
with lifetime replacement
Old Apr 18, 2004 | 03:26 PM
fw190bvi's Avatar
j00 get piping from kteller????
if i go FI i think im gonna use his 3" piping
Old Apr 18, 2004 | 04:43 PM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SearchBeforeUPost! &raquo;</TD></TR><TR><TD CLASS="quote">do you mean the rim weighs less?
Also, the wider tire will decrease your gas mileage. </TD></TR></TABLE>
which physics make something weigh more when mounted on a car?
does teh car have some sort of gravitational field that is different from the earth's???
Old Apr 19, 2004 | 09:10 AM
Default Re: 2 questions 4th gen (v4lu3s)
no smart ***, but the bigger the diameter of the wheel, the more rotational inertia it creates. You would be the last guy I would expect to hear a question like that from. Also, we could get into sprung v. unsprung weight.
If you test the acceleration of a car with a set of 15" wheels, and then with a set of 17" wheels that weight the same as the 15" wheels, the acceleration will be quicker with the 15"s. Damn Willie, I am getting worried about you.
Old Apr 24, 2004 | 04:03 AM
Here is an excellent thread to read:
http://www.cb7tuner.com/vbb/sh...=5713
KyoCivic98
17
Aug 21, 2009 04:21 AM
LSintegra
Jan 19, 2006 11:45 AM
Declectic
Feb 14, 2005 12:30 PM
JohnnyLux
Aug 30, 2004 07:51 PM
Chris_R
Sep 5, 2001 09:35 PM
