NEED TO MAKE H22 SMOG IN 92 EG6
THE COPS GOT ME AGAIN! They sent me to the ref. this time. He of course failed me and told me to put my stock motor back in. HAHA! I have it registered in a smog exempt city but the ref said I still have to pass smog because of the citation code the cop gave me. So I need someone to tell me exactly what I need to put in to pass smog. I cant get rid of my hatch. I'll sell it befor I put it back to stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22CREW »</TD></TR><TR><TD CLASS="quote">He of course failed me and told me to put my stock motor back in. </TD></TR></TABLE>
man, that sucks. Hope it works out for you and the car passes.
damn that sucks cause if you did all the cutting etc in the bay, its basically stuck as a h22 car now.
you better try to hook up all the emissions stuff
good luck
good luck
just to name a few of the things i need to pass the ref: egr, egr solenoid, map, air boost valve, um...pcv, iat, and a couple more, i believe i named the right things but i may just be puttin random letters together...anyways, the ref should have told u exactly what parts are missing that you need to put in, i got a vacuum line diagram and he circled all the parts i needed
Yeah you really need the vacuum diagram from the helms manual. That will help you out a ton. You need all the egr stuff, starting air valve, purge solenoid, usdm p13 (however I don't know if the ref really knows the difference between the jdm and usdm ecu, stock header (can be a jdm stock header if you can't get ahold of a usdm one, the ref won't know the difference) or a header with a carb # (ie dc or greddy), and a 92-96 PRELUDE VTEC intake with a carb number (an AEM short ram will work) or you could try to get away with some sort of stock air box. The rest just depends on how **** your ref is. If you have all these things and your cat is working properly you shouldn't have too much trouble passing.
Good luck.
Good luck.
bigbacon2
Jun 24, 2004 03:47 PM
