WTF! Tranny housing won't go back together...
Old Oct 29, 2001 | 07:00 PM
boomslang's Avatar
Default WTF! Tranny housing won't go back together...
Man, I just spent the last hour trying to get my tranny housing back together. The tranny housing will lower until it is about 1/2 of an inch all the way around and won't go down any farther. All the shift forks are lined up. The pins in the housings aren't touching yet so I know it isn't them causing it to not go together. What the heck is going on? I can't figure it out.
The clip on the top of the mainshaft is aligned properly too.
Old Oct 29, 2001 | 08:34 PM
BreakStuff's Avatar
New User
Default Re: WTF! Tranny housing won't go back together... (Inlinefour)
A gear placed in upside down will also create this mess.... what ever you, don't force it!
you have already took into consideration the obvious reasons, shifter forks have to be aligned as well as the mainshaft spacer..are you getting caught on the mainshaft snap ring?
[Modified by BreakStuff, 12:38 AM 10/30/2001]
Old Oct 30, 2001 | 06:31 AM
boomslang's Avatar
Default Re: WTF! Tranny housing won't go back together... (BreakStuff)
No, the snap ring isn't even touching the shaft yet. None of the gears could be in upside down, I just pulled the diff out and put it back in. I didn't do anything to the countershaft or mainshaft gears besides lift them up to get to the diff.
Thanks Phantom Grip!
[Modified by Inlinefour, 9:32 AM 10/30/2001]
Old Oct 30, 2001 | 01:05 PM
Blown90hatcH's Avatar
What about the spacer on the top of the main shaft? The one with the little tab on it that goes into the groove? Also....you need to lube that thing up like a champ. I have been fighting broken bearings and crap with my trans and have run into this problem too. I have to put like a half quart of oil all over everything.
That is funnny
[Modified by Blown90hatcH, 2:06 PM 10/30/2001]
Old Oct 30, 2001 | 02:07 PM
bfast's Avatar
also try putting the gear set into 4th gear before sliding case on.this helps to keep
everything aligned.
Old Oct 30, 2001 | 05:02 PM
boomslang's Avatar
Default Re: WTF! Tranny housing won't go back together... (bfast)
Thanks guys. I will give it another try when I work up enough patience.
Old Oct 30, 2001 | 08:27 PM
boomslang's Avatar
Okay, I go the housings back together finally, one of the shifter forks wasn't perfectly aligned.
Now the c clip on the countershaft is acting like a s.o.b. and won't snap into place.
Old Oct 30, 2001 | 09:25 PM
I think that I have this mastered......use some snap ring pliers and spread the c-clip apart....Then tighten down the casing some....about half way or so....this will make the c-clip stay open......Then get 2 phone books.....flip the trans upside down...and give it one solid bounce on the phone books....should fall right in.
Old Oct 31, 2001 | 07:08 AM
boomslang's Avatar
Default Re: WTF! Tranny housing won't go back together... (Blown90hatcH)
Good idea, I am gonna try it. I have the c clip spread open and the tranny case tightened down, it's so close to snapping in...
Old Oct 31, 2001 | 07:50 AM
Bounce it upside down nicely.........it will snap in...good job
Old Oct 31, 2001 | 12:51 PM
boomslang's Avatar
Man, that idea is pure genius! Worked on the first bounce! Thanks
Old Oct 31, 2001 | 01:26 PM
92sleepR's Avatar
New User
"Now the c clip on the countershaft is acting like a s.o.b. and won't snap into place"
Use the old "bounce" method. Turn the trans upside down and GENTLY tap it on a board. The main shaft will seat properly and you will hear the snap ring click into place.
Mike
Old Oct 31, 2001 | 01:31 PM
After about 15 tries....I finally learned how to get it on there easier...Good job man...glad to hear it back together.
Old Nov 1, 2001 | 07:00 PM
BreakStuff's Avatar
New User
An easier method to get the snap ring into place is to get the snap ring to the halfway point and insert a flathead screwdriver into the bearing groove and lift up on it..
Old Nov 1, 2001 | 07:07 PM
Doesnt work as easy....actually that method kills the threads on the inside of the casing.
Old Nov 1, 2001 | 07:22 PM
BreakStuff's Avatar
New User
Now you know why my name is BreakStuff!
Old Nov 1, 2001 | 07:24 PM
LOL...true...I got pissed...tried it your way...killed the threads and got the phone book....
Old Nov 2, 2001 | 06:21 AM
boomslang's Avatar
Yup, just get out the phone book. It's so easy.
DC_RaceR
Oct 8, 2006 04:16 PM
Honda Bull
Oct 22, 2005 02:11 PM
sloaccord
Mar 23, 2005 10:31 PM
Speedra500
Apr 7, 2004 05:19 PM
boomslang
Oct 30, 2001 08:29 PM
