VAFC anyone using it with an LS brain?
Old Apr 17, 2004 | 05:45 PM
JDM KING's Avatar
Default VAFC anyone using it with an LS brain?
I searched and all i got was "VAFC FS" so i hope this isnt a repost and if it is im sorry, Well just wanted to know if you guys out here ever used the vafc without a vtec ecu, and i was wondering if you can wire it up directly to the selonoid and control vtec function from the vafc itself! any help would greatly be appreciated! im just curious because my buddys got a good LS ecu and has no rev-limit on that, and instead of buying a ecu he wants to just run the vafc!
Old Apr 18, 2004 | 07:40 PM
JDM KING's Avatar
Default Re: VAFC anyone using it with an LS brain? (Allmotordc2integ)
Anyone???? damn it must be so ghetto that no one does it???
Old Apr 18, 2004 | 08:56 PM
sol_1320's Avatar
I have works real good
Old Apr 19, 2004 | 12:08 AM
JDM KING's Avatar
Default Re: VAFC anyone using it with an LS brain? (sol_1320)
how did you guys wire it????directly to the selonoid?
Old Apr 19, 2004 | 02:34 AM
sol_1320's Avatar
my bad I miss understood post good luck
Old Apr 20, 2004 | 12:02 AM
JDM KING's Avatar
ANYONE?????
Old Apr 20, 2004 | 07:52 AM
Dr. EKology's Avatar
From my knowledge, no, you cannot use a non-vtec ECU. Reason being that the VAFC needs a base map to run off of. All it does is modify the map you are currently using to whatever you have it set to, so yes, a VTEC ECU is needed for your VAFC to have a fuel map etc. to modify.
twiztid00002
Jan 14, 2008 09:31 PM
wicked_b16eg
Dec 30, 2007 11:10 AM
slow_redcivic
11
Jan 12, 2006 07:52 PM
IgniteTeg
Apr 30, 2002 10:56 PM
